Completed the hard part of homemade 3rd scv remotes install
   / Completed the hard part of homemade 3rd scv remotes install #21
Can I ask for the size of the fittings you used for front an rear,I used your pic. To make my 4700 work with out 1200.00 kit they want now, I would like to do front an rear connections like your's. Jd won't give me size of fittings, thanks jws64
   / Completed the hard part of homemade 3rd scv remotes install #23
   / Completed the hard part of homemade 3rd scv remotes install #24
On my 4400 the third SCV ports are ISO 6149 female metric o-ring with M18x1.5 threads. The factory kit uses metric to o-ring face seal adapters which mate to the steel hard lines that come in the kit. If I was doing a homebrew kit using hoses rather than hard line, I'd probably get adapters to go to 3/8" JIC. Avoid pipe thread whenever possible IMO.
967-6-18 | 3/8" JIC Male x M18x1.5 Metric Male: DiscountHydraulicHose.com
Looking back at the OP's pics, it appears his unused 3rd SCV is the outer one. On mine it is the inner, the outer two run the loader. I had to disconnect the loader lines to get a wrench on the inner fittings...bit of a pain and less spacious than OP's pics. Check which way yours is configured.
   / Completed the hard part of homemade 3rd scv remotes install #25
Thanks for help! Mine are inside also, I am going to use hoses instead of hard lines. Well send pic. When finished.
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
Informational Lot - Financing (A55315)
Informational Lot...
2013 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2013 Ford F-550...
2019 Kia Soul SUV (A53424)
2019 Kia Soul SUV...
16001 (A55853)
16001 (A55853)
