Completed the hard part of homemade 3rd scv remotes install
   / Completed the hard part of homemade 3rd scv remotes install #21
Can I ask for the size of the fittings you used for front an rear,I used your pic. To make my 4700 work with out 1200.00 kit they want now, I would like to do front an rear connections like your's. Jd won't give me size of fittings, thanks jws64
   / Completed the hard part of homemade 3rd scv remotes install #23
   / Completed the hard part of homemade 3rd scv remotes install #24
On my 4400 the third SCV ports are ISO 6149 female metric o-ring with M18x1.5 threads. The factory kit uses metric to o-ring face seal adapters which mate to the steel hard lines that come in the kit. If I was doing a homebrew kit using hoses rather than hard line, I'd probably get adapters to go to 3/8" JIC. Avoid pipe thread whenever possible IMO.
967-6-18 | 3/8" JIC Male x M18x1.5 Metric Male: DiscountHydraulicHose.com
Looking back at the OP's pics, it appears his unused 3rd SCV is the outer one. On mine it is the inner, the outer two run the loader. I had to disconnect the loader lines to get a wrench on the inner fittings...bit of a pain and less spacious than OP's pics. Check which way yours is configured.
   / Completed the hard part of homemade 3rd scv remotes install #25
Thanks for help! Mine are inside also, I am going to use hoses instead of hard lines. Well send pic. When finished.
2006 INTERNATIONAL MA025 BOX TRUCK (A56138)
2006 INTERNATIONAL...
23222 (A50323)
23222 (A50323)
2000 Morbark Towable Brush Chipper (A55851)
2000 Morbark...
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
2014 Dodge Charger Sedan (A55973)
2014 Dodge Charger...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
