Compacting gravel driveway
   / Compacting gravel driveway #91
I'm getting crashed stone delivered and spread on my old gravel driveway. I will crown and level it. Then a guy with vibrating roller will come over and compact it. Would it be a good idea to have stone dust spread on top before compacting? Please share your experience/ideas/suggestions...
If you get crushed stone or gravel (which helps interlock) Smaller stone could be vibrated in the "lock in " the surface and make it smoother. Stone dust will just settle in/wash off the next rain event.
   / Compacting gravel driveway #92
I'd be hard pressed to tell you they are equal to concrete or asphalt.
They aren't but a dam sight better than gravel. I didn't pay nearly that much for what I got because the outfit was milling a parking lot up town so the transit distance was short and they even came hot. Like I said, 2 years now and looks just like it was done yesterday and they laid on a thick layer as well. Guy down the road saw what they were doing and got some for himself.
Never go back to gravel and I suspect I won't have to because I expect this to last at least a decade.
   / Compacting gravel driveway #93
   / Compacting gravel driveway #94
This may be a bit late, but we’ve done similar this spring. We have a 1/4 mile driveway which was built with crushed 3/4 minus on top of recycled crushed concrete. This spring we spruced it up (after 5 years) with ~34 yards of crushed 3/4 minus (granite) ‘tailgated’ the length of the driveway. I smoothed with a ‘land plane’ , then did a final smoothing with my front bucket (when damp, the crushed rock with minus material tends to form a few clumps coming off the land plane).
For us, normal traffic has been sufficient for compacting.
   / Compacting gravel driveway #95
All the compactors I've seen (not that many) have the ability to spray water in front of the rollers.
   / Compacting gravel driveway #96
Those sprayers aren't sufficient or intended to add moisture to rock; they are meant to cool and prevent asphalt from sticking to the drum.
   / Compacting gravel driveway #97
When I top dress my driveway I get screened gravel, commonly call #57 or #67 or fine screened. My driveway is too steep for crusher run and fines, the dust gets carried away to easily by the rain and you are left with loose rock.
My driveway climbs ~21' with 79' on the slope. I don't know if that's as steep as yours, but if I don't roll it wet both the fines and the smaller rock will wash down hill in a inch per hour rain. If I roll it wet with a slight crown, even a 4" per hr rain doesn't cause much damage. I use a poly 46" lawn roller behind my BX multiple passes and I go SLOW.
   / Compacting gravel driveway #98
Spent the last 50 years in construction. Dry dirt and gravel particles must be slightly wet in order to lubricate the particles & grains so they slide past each other in the compaction process. Too much water makes mud & mush. Too dry results in light compaction.
   / Compacting gravel driveway #99
Would love to see some more analysis of the CONCRETE option mentioned above....DO it ONCE and forget it....esp on hills.
   / Compacting gravel driveway #100
Before even considering concrete, you need to have an idea how long the drive is. If you are dealing with something sub 200 ft long, upto 12 ft wide, and are somewhat handy, and have beer and friends, it's not That expensive.
If you figure something like $70-85/sq yard.
say, a 12 ft drive, 100lf, 1200 sq ft @ 6" thick= we get about 23 cubic yards= about $4000 in concrete, delivery, wire, form boards. So expensive but no crazy for that short of a drive. That's also entirely pourable by 2 or 3 guys in a day. When we start talking about 800 foot long; we start needing to get a full crew of guys. If your seriously considering it; recommend reading that other thread, as there is a lot of detail.
Concrete still needs your subgrade problems resolved, so if you are dealing with springs, muck, sloppy trash, organics, those still need addressed.
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
2018 Big Tex Tandem Equipment Trailer (A52384)
2018 Big Tex...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A53472)
Kubota SVL65-2...
2013 Chevy Silverado 2500 HD (A53472)
2013 Chevy...
2018 Mazda CX-5 SUV (A51694)
2018 Mazda CX-5...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
