Compact Tractor Purcahse.
/ Compact Tractor Purcahse. #1
ToolcatWonka5610
Mount Morris, Michigan
My Dad is going to buy a Compact tractor for his landscaping business and I'm helping him out. He's currently looking at a John Deere 3320:), a Kubota L3240:D, and a Bobcat CT335:rolleyes:. It would have a Factory Cab, Loader, Mid Mower, and a Top and Tilt Kit. What do you guys think?:confused:
/ Compact Tractor Purcahse. #3
If you have a good local New Holland dealer, you might check out the T2310. It's a little more hp (40 engine hp) than what you've listed but the cab has AC standard. Another nice option when using a mid mower is "super steer" for navigating around landscaping. Good luck! Dan
Partspring original Ford/New Holland parts
/ Compact Tractor Purcahse. #4
Can you get a cab on the Bobcat?
Kyle
/ Compact Tractor Purcahse. #5
Yes, you can get a cab on the Bobcat. The brochures my dealer sent me show a CT335 with one and it says within the cab information...."a smaller cab is available for our smaller tractors". But it doesn't say anywhere in any of the brochures which models have the cabs available.
/ Compact Tractor Purcahse. #6
I wouldn't get a mmm for a tractor you intend to use for commercial landscaping, a seperate unit for grass cutting will cost more, but it'll be worth it. as for the machines in question, a little more info as to uses would be helpful. if he intends to use the machine for hardscape installs I'd suggest the next frame size up (the JD 4x20 series). the 3320 is not going to have the capacities needed for off loading/moving pallets of sod or block/stone.
/ Compact Tractor Purcahse. #7
If your dad is looking to buy a hydrostat, the hst+ in the kubota blows away anything in its class.
Well we don't do stuff like that right now. We just landscape peoples yards and stuff. Loading and maybe Tillage would be the mainly applications. Mowing would not be main, but we would still mow. Snow removal in the winter also. So far we lke the John Deere and Kubota Cab tractors. We still have yet to see the Bobcat and we would like to check out New Holland. Any other suggestions?
/ Compact Tractor Purcahse. #9
Check out the Kioti CK45se.
Is it a Factory or Allied Cab on the smaller Machines and does it have Heating and A/C? But this Bobcat Dealer gave me and my a great price for a Toolcat 5600; 2008, Demo 40Hrs, the whole cab setup, Power Bob-Tach for an extra $930. Regular price of a Toolcat 5600 that the same dealer quoted my Dad is around $48K but this demo Toolcat is only $39,000. Still New! What do y'all think?
/ Compact Tractor Purcahse. #11
I think you can buy a lot of CUT, plus a pile of landscaping attachments for $39,000...
My .02
/ Compact Tractor Purcahse. #13
I really like my ToolCat 5610. More than any other cut I have owned including Kubota 3710, Case-IH DX29, and cabbed JD 3720. The price of the TC is the killer compared to CUTs. However, a loaded, cabbed JD 4X20 series is getting close in price to a TC. If you have a skid steer (I have a Bobcat S300), then the TC becomes much more apealing because it can share attachments. You can also easily rent front attachments for specific jobs when needed. I buy most of my front attachments used and save 50% or more. Just bought a nice Cat 7' sweeper and Bobcat tiller for $2000 total. The 5610 with 3 pt and pto also allows the use of cheaper 3 pt equipment. The TC lifts well, turns sharper without disturbing the ground, superior front visibility, very good rear visibility, more stable when lifting or on hillsides, smoother riding, higher flow hydraulics, great hydraulic controls, can carry 2, lower in height than many cabbed CUTs, and better more traction due to all 4WD and weight.
I will probably get slammed for this, but the Case-IH (NH clone) was probably my least favorite of the brands. Haven't used Kioti/Bobcat.
We are going to get a 5610 in the future when we make that kind of money. But today I looked at a Case 55 cab tractor and had some features I like on but thing is that we've been looking at Case and New Holland but the smallest Cab you can get is 40hp and were looking for something a bit smaller but 40hp would be the max for us. I'm also looking at a TYM 403 cab with a loader.
Question: Can you get the PowrReverser on a John Deere or any Cab tractor?
The Kubota L3240 were checking out is probably the one we like the best so far.
We love that HST+ and its got a lot of the same features of the Deere.
For a really good price!
So one thing I've been wondering: I heard John Deere a 1055 Compact Tractor around '94 for a couple years. It was one step up from a 955. If anyones got any info or pictures on a 1055, send them to me. I wanna see one.
iDrive TDS-2010H...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
Hydraulic Auger Bits (A61572)
Hydraulic Auger...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
SET OF REDDICK SADDLE TANKS AND FRAMES (A63745)
SET OF REDDICK...
