Compact Track Loader, whos the best?
   / Compact Track Loader, whos the best?
I once hired a guy by the hour who was reasonable, his machine was junk and he billed me for two repairs while he was here. It was not a good deal!
   / Compact Track Loader, whos the best? #102
So, regardless of what the client sees, you still need a number for your time to throw on bids, plus materials, and where I think Many small guys go wrong, Profit. You should be paying yourself, your equioment/helpers, your material (with some profit), and then company profit after you paided your wages to yourself.
   / Compact Track Loader, whos the best? #103
And if you run an expensive brush mower, add even more. Dirt work isn’t going to bring the same coin as brush mowing.
I have done very well renting a large frame with a forestry mower for a week and doing clearing work.
And you have to cover the government fees, like taxes, Social Security, licensing, compliance fees, and future legal fees, I guess I am tired of the government!
   / Compact Track Loader, whos the best? #105
I agree completely with bidding a total job cost but my opinion still remains that if you need a 16,000 pound $150,000 skid loader then you actually need a real dozer.
   / Compact Track Loader, whos the best? #106
Re billing. Remember machines are wearing out as you use them. Need to charge enough to cover expenses pay yourself well and save up for machine repairs or replacement. I’ve said it here before the best thing I did as a dirt working business was going from homeowner work to underground utilities.
   / Compact Track Loader, whos the best? #107
As far as brands go, I don’t think you can really go wrong with any of them. Whatever one brand may have as a slight advantage of another, could be more than offset by a lower purchase price or better dealership support.
Just buy what brand makes the most sense for you. A well cared for lesser unit may prove better in the long run than a nicer unit that was run hard & put away wet.
I usually buy more machine than you think you need. Leaves room to grow.
I demoed a brand new Tackuchi before I bought my Kubota machine and I’ve ran a few older ones on jobs and I wasn’t impressed. A Kubota cab isn’t exactly luxury but the Tackuchi cab was sure enough basic. The Kubota 75-3 actually has a much improved cab over the previous models. The Tackuchi step into the cab is too big and significantly impairs the visibility of the bucket edge. The Tackuchi controls are loose especially the steering to the point it was difficult to accurately place pallet forks in the pallet. I used 2 brand new ones and they were both like that as well as the older ones. I’m not saying they’re a bad machine, they aren’t and I’d buy one if the deal was good but they certainly aren’t industry leading like some people seem to think. I looked at a Tackuchi mini x as well and it was fine but the Kubota price was better and the Kubota dealer was offering a better trade for my used Kubota as well so I bought another Kubota.
Thanks for this informative info, after a great deal of research I am 99 percent sure I will go with a Cat 249D3, and I will fill you all in on it when it happens and give you updates on price and other info I have learned. Price was a big part of it, Cat was very reasonable compared to others.
   / Compact Track Loader, whos the best? #110
A lot of things to unpack for you. Primarily, you need to decide what you are going to use the machine for. I use mine for forestry work and mulching, so HP and hydraulic HP were a primary concern.
I've owned NH C238, C345 and now the Takeuchi TL12v2.
I looked at everything while making the purchase decisions.
The Tak has the biggest cab, a Kubota engine and is one of the most powerful machines for mulching.
Things I like about the Tak:
Lift up door is fantastic. You can get in and out of the machine, without the lift blocking the door. Handy in an emergency or if you get stuck with the arms a few inches off the ground. The high-flow machine comes with six hydraulic connectors. It makes it very easy to run complicated pieces of equipment, like a six way blade or a boom-swing mower. As I said, the cab is huge and nice. Not sure what someone else was complaining about. These are luxury cars.
Tak cons:
Biggest issues, it takes too people to safely lock the loader arms in the up position if you need to work on it. Absent that, you are going to have to pray that the arms don't fall at the exact instance that you get out. I don't like that. Also, for whatever reason, the Tak doesn't allow you to lock the hydraulics on in continuous flow in both directions (unless they finally updated). This is sub-otimal when running a Harley rake or a bi-directional mower. Probably my biggest beef. There are also differences in the V model and R model, which you should look into and understand.
New Holland pros:
Nice cab, they are shorter as NH maintains the position that farmers need to get the machines into low clearance barns. Fair enough, but that leads to one of the cons below. You can lock the arms up for maintenance from within the cab. This is a very nice piece of mind. That safety is one of the reasons that people like the JCB/Volvo machines too. You can lock the hydraulics into continuous flow in both directions (Not HF, but that is normal for all machines I've seen). They do offer an enhanced HF which requires a jumper in the 14 pin connection.
New Holland cons:
Swing out door, which is a result of the lower, smaller cab. NH maintains there isn't enough room for the the door to maneuver overhead. The door issue then leads to problems entering and exiting when you have hydraulic lines hooked up. You essentially are blocked on the left by the hoses and on the right by the door if you can't go straight ahead because of the type of attachment. Kind of odd they don't put the connections on the same side the door swings out. You can now get a machine that matches the TAK power output, but at the cost of getting a 16,000lb machine. That gets into the territory, where you start needing much bigger truck and trailer to move it. For reference, the TAK is closer to 12K.
The biggest thing you should consider, IMO, is dealer support. It can be very handy to have a good, responsive dealer.
For commercial type work, or heavy duty use, I'd recommend you look at Tak, CAT or Deere.
Farm and Ranch, you 'd probably be happy with Kubota or NH/Case
Occasional, budget constrained but with excellent dealer support, you could look at the Gehl, Yanmar (new product), JCB or various other "off" brands. I would shy away if I didn't have a dealer that I was confident was going to support these and be around for the long haul.
Your usage plans will really dictate what you want. Don't go to small though, you'll be surprised how much you tax these machines with all the attachments you can get. I have close to 20 different ones and use the all.
Tree Boom Skid Steer Attachment (A56860)
Tree Boom Skid...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND69FDGH1752 (A57453)
2015 Freightliner...
2011 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59575)
2011 FREIGHTLINER...
206707 (A58375)
206707 (A58375)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
