Compact Hydraulic Valve
/ Compact Hydraulic Valve #11
You have two choices. <ul type="square"> [*] First you can use the rear aux hydraulic block (you will need the $65 adapter). This is where most people connect to that have a FEL.
[*] Or you can use the front hydraulic block that the FEL connects to (you will need a different adapter and o-rings), but this will preclude you from having a FEL in the future. [/list] In both cases you will still need the return to tank line that connects to the transmission. Just remove the plug and screw in you hose.
296385 (A57192)
296385 (A57192)
40' CONTAINER (A52706)
Broom Attachment (A59228)
Broom Attachment...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
