Commercial Wood Chipper
/ Commercial Wood Chipper #1
WVH1977
Platinum Member
Richmond, VA
Massey 2860M Cab, Massey 1E.35, Gravely Pro-Turn 560, 1989 Ford D47 Dump Truck John Deere LX178
Does anyone on here have a commercial grade wood chipper, like Vermeer, Rayco, etc.? I have been thinking about about maybe buying one to use on my land for pine trees that are 6 inch and under. I have 16 acres of pines and thinning them out. Thinking I can reuse the pine mulch by spreading on the ground where needed.
Has anyone done something similar? I am getting tired of burning all of it.
/ Commercial Wood Chipper #2
@oosik does a ton of chipping small ponderosa pines using a 3ph unit. My guess is that your Massey and NH could easily run a chipper for that size pine, a lot cheaper than a commercial grade.
If you're set on going commercial, I'd check out the arboristsite.com forum, discussions about commercial grade chippers show up often. Search first.
/ Commercial Wood Chipper #3
I have a Bearcat 8993 9” chipper and a Bearcat 5 “. Had the same chipper in pto but my tractor Kabota has a backhoe so conversion was a super pain. My e9” unit is super with feed controlled to maintain chipper speed. Quite the jump up in price for diesel engine. I don’t expect to wear my gas out.
/ Commercial Wood Chipper #4
A commercial unit… id love to get one myself. Until i saw the $30k up prices for a decent used one….
I bought a pto unit years ago. 6” max. Works great, but slow.
/ Commercial Wood Chipper #5
I would love to own a diesel 12-15” chipper. Look at used ones on FBM a lot.
10K buys you a pretty wore out chipper. 25K gets you a nice one. I use one about 5-10 times a year, so I just rent and build it into the job price for the customer. Seems to work out just fine
/ Commercial Wood Chipper #6
As I have aged, slow has become a virtue. I have an electric log splitter that takes over a minute to cycle; half-way through a FEL bucket of split logs, the slowness is fine with me. Oosik and I have 6" Wallenstein and Salsco PTO chippers that suit our purposes well.
/ Commercial Wood Chipper #7
In my experience, burning is much faster and easier than chipping. A bigger shipper will wear you out really fast dragging stuff and feeding it. I started feeding mine with a mini-ex and that helps a lot, but it's still much slower than burning. But everyone's situation if different, so perhaps rent one for a day or two and see how it goes. Then decide what's best for the long run.
/ Commercial Wood Chipper #8
I have rented a couple of commercial style chippers and I would not look at a power feed unit without two driven infeed rollers. The single roller was much harder to get branches to start feeding and seemed to have more feed problems than twin roller. I believe both similar size in 9 - 10” capacity range.
Note: Being rentals they easily could have not been maintained or setup properly causing the problem.
2022 EZ-GO ELITE...
3pt Hitch Receiver  (A62679)
3pt Hitch Receiver...
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
SARLO (A64557)
SARLO (A64557)
Iranch IRET13 (A64127)
2017 Bobcat T770 Compact Track Loader (A63689)
2017 Bobcat T770...
