two_bit_score
Super Star Member
- Joined
- Dec 22, 2008
- Messages
- 12,572
- Tractor
- John Deere 110 TLB, Diamond C 19LPX GN trailer
I know this has been discussed but want to input my thoughts. New B2930 with 60" mmm adjustments to get level was little bit of work and all links rear and front not at same adjustments - That tells me either tractor links or mmm is not square from factory. Rear link to 2 point arm is a joke, Why couldn't they engineer a link direct off the 2 point main shaft on left side and not use the poorly designed arm that goes over two point arm chewing it up. Also the height adjustment - yes everyone the height adjustment. My kindergardner could design something better, should have a adjustable link lever connected to main lift system like other brands. I did remove and fashioned a plastic spacer shim to go on top of cam and reassembled to take the play out of the assembly and keep it tight as not to move when weight is off cam. Brakes same side as hydro pedals was that engineer on drugs or hung over that day? Other than that love the tractor in every respect so far. My thought on Engineers if they had to work/service what they design we would have well thought out designs on everything we use. They sit at their cad systems designing in the cubicals and never get out in the real world. The few that do change there inefficient designs to work properly.:confused2:
Seriously. Why did you buy it if it was such a piece of junk? Did you not look it over? Check it out? No research? Did they force you? Got conned by a slick salesman?
