Colvert???
/ Colvert??? #41
Glenn, there was a 24" pipe in the creek to begin with and the creek was a short distance (20 - 30 feet) from the bottom of a steep hill. I wanted to not have such a steep approach to the creek so I put in the 48" pipe and built the road up. There is about 2 feet of fill on top of the pipe. The original pipe was about level with the banks of the creek so the 48" pipe was almost 2 feet higher than the creek banks. Therefore the sides of the pipe had about 4 feet of fill around them (2 feet to the top of the pipe and 2 feet on top). I did not need to bend the pipe since the creek was straight at this point so I did not need to bend the pipe. I do not think the pipe can be bent though. I think the pipe is adequately sized but we have not had enough rain this year to give it a really good test but there has been no problem so far. The old pipe did not handle the flow during quick, heavy rains. The creek sometimes overflowed 15 - 20 feet out of the banks. This has not happened since the 48 " pipe has been installed. The cost of the pipe was a lot more than I anticipated. I did not shop around because I trusted the contractor that was doing the work for me. I put in 2 30 foot by 48" pipes. He charged me $800 for a new one and $400 for the other one that he had used temporarily on another job. So I don't know how the price for a metal pipe compares with this.
/ Colvert??? #42
I just added 12' to one end and 8' to the other end of my driveway colvert. It is a 12" metal one. I got a 20ft. new pipe and just cut it with a sawzall (very easy to do!). Got two collers to mate the ends up and put a fan flange on the inlet side. This was covered with crusher run and then with topsoil. I did this so that the water would not run along the side of the colvert, and when freezing not heave the colvert onto my newly paved driveway. I hope it does the trick. The new colvert was $113.00 and the two collers were $6.00 each and the flange was $48.00. If it works it was money well spent.
Von
2014 Mercedes-Benz GL 450 4MATIC AWD SUV (A61574)
2014 Mercedes-Benz...
2017 Cat 316FL Excavator (A62679)
2017 Cat 316FL...
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
2005 GMC C5500 (A64127)
2005 GMC C5500...
Bobcat E80 (A64126)
Bobcat E80 (A64126)
Rhino HPHD (A64127)
Rhino HPHD (A64127)
