Cold water tractor loader just ordered!
/ Cold water tractor loader just ordered! #21
My loader came with an adapter designed to T into the supply and return lines that run along the bottom right side of the transmission housing. Only took a few minutes to plumb in.
/ Cold water tractor loader just ordered! #22
Your 186 has a diverter where the high pressure line enters the 3 point. Should be two plugs in top of it. Without being able to look at it I cannot tell you just how it works. Maybe someone with a 186 will chime in. I don't think you should need the hydraulic fittings from Hoye with your 186.
Stumbled across this picture of what I am talking about. http://www.tractorbynet.com/forums/...9662-yanmar-186d-hydraulics-problem-image-jpg
/ Cold water tractor loader just ordered! #23
did the loader come with a loader valve, or do you have to purchase 1 ? if you have to order 1, will you get joy stick or the 2 stick loader valve, float.non float,PB ??
I will send a picture of what mine looks like soon.
/ Cold water tractor loader just ordered! #25
Is there an easy way to make it quick attach/detach?
/ Cold water tractor loader just ordered! #26
I bought my 2210 DB and my loader and post hole digger from them. Although I was a little disappointed in the fact that my tractor WAS NOT serviced in any way/shape or form and my 4x4 died within an hour of use (locked up, bad bearing) and had to be rebuilt, I LOVE THE LOADER. I picked it all up as they are 8 hours from me and since I rebuilt the 4x4, so far (FINGERS CROSSED) no more issues thanks to the fellas on here and lots of advise.The loader works wonders.
Looks nice. I will be getting the loader next Wednesday. It's sitting an hour away. They don't deliver up here till then. **** mad !
New/Unused Landhonor LHR-CSC10 Squeeze Chute (A65583)
New/Unused...
2715SSFL (A61567)
2715SSFL (A61567)
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
360 Y-Drops (A65640)
Peruzzo Canguro 1600 Collection Flail Mower
Peruzzo Canguro...
