Cold water tractor loader just ordered!
/ Cold water tractor loader just ordered! #21
My loader came with an adapter designed to T into the supply and return lines that run along the bottom right side of the transmission housing. Only took a few minutes to plumb in.
/ Cold water tractor loader just ordered! #22
Your 186 has a diverter where the high pressure line enters the 3 point. Should be two plugs in top of it. Without being able to look at it I cannot tell you just how it works. Maybe someone with a 186 will chime in. I don't think you should need the hydraulic fittings from Hoye with your 186.
Stumbled across this picture of what I am talking about. http://www.tractorbynet.com/forums/...9662-yanmar-186d-hydraulics-problem-image-jpg
/ Cold water tractor loader just ordered! #23
did the loader come with a loader valve, or do you have to purchase 1 ? if you have to order 1, will you get joy stick or the 2 stick loader valve, float.non float,PB ??
I will send a picture of what mine looks like soon.
/ Cold water tractor loader just ordered! #25
Is there an easy way to make it quick attach/detach?
/ Cold water tractor loader just ordered! #26
I bought my 2210 DB and my loader and post hole digger from them. Although I was a little disappointed in the fact that my tractor WAS NOT serviced in any way/shape or form and my 4x4 died within an hour of use (locked up, bad bearing) and had to be rebuilt, I LOVE THE LOADER. I picked it all up as they are 8 hours from me and since I rebuilt the 4x4, so far (FINGERS CROSSED) no more issues thanks to the fellas on here and lots of advise.The loader works wonders.
Looks nice. I will be getting the loader next Wednesday. It's sitting an hour away. They don't deliver up here till then. **** mad !
Metal Donkey Statue (A64127)
Metal Donkey...
Hedge Posts (A65640)
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
Skid Steer Post Auger (A65640)
Skid Steer Post...
(1) 30 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
