Cold start during break-in period?
/ Cold start during break-in period? #1
motownbrowne
Elite Member
river falls, wi
Kubota mx4700 HST, New Holland TC-29D
Should I avoid doing this? It's -7F here, and I don't need to run the tractor today. My chores could wait for a couple of days till it's in the twenties, but since the tractor is brand new I'm having a hard time holding back. What do you think?
/ Cold start during break-in period? #2
Good things happen to those that wait!
/ Cold start during break-in period? #3
They designed the thing to work in the winter didn't they? I personally think the entire break in thing is a lot less necessary then it used to be.
/ Cold start during break-in period? #4
It doesn't have anything to do with breaking in, I don't use mine when it's really cold if I don't have to. The first few seconds after starting are the most wear on an engine, if the oil is cold the wear is greater. A battery at that temp has probably lost 60% of it's capacity, and the starter is trying to spin a frozen engine. Can't be good for anything. If you really need it use it, if you can put things off a day or two I'd wait.
/ Cold start during break-in period? #5
I don't see a real problem, although cold starts are never good for an engine. If you have a block heater definitely use it for at least an hour or two before starting, and let the engine warm up before working it.
If you're not comfortable, it definitely won't hurt anything if you DON'T run it..
Sean
/ Cold start during break-in period? #6
The main issue I could see is oil viscosity,, do you have a block heater? If the oil / block are plugged in, no worries.
/ Cold start during break-in period? #7
You know the tech answer, wait a couple days
/ Cold start during break-in period? #8
Is your tractor sitting outside??? It is cold here, but garage is in the 40's. Does the break-in period call for no starting below a certain temp??
Tractor is outside. Air temp is -18 this morning. The manual doesn't say anything about cold starting, but I thought I'd see what the opinions were. I started it yesterday at 7 degrees after two hours on the block heater. Started just fine, but I won't be trying today. I'm sure it would work, but it's supposed to be 30 tomorrow, so I can hold off.
/ Cold start during break-in period? #10
You'll be sorry if that snow starts getting wet.
Just do it, it cleans up better if it's colder and that skim that's left behind has a chance to melt and run off went it does warm up.
I guess there's that side of the coin too. Luckily we don't have any fresh snow on the ground. There is snow along with those warmer temps forecast tomorrow, so I'll get to go play then. I will say that it was pretty incredible to move two pallets of firewood, one refrigerator, and a wood stove yesterday, without bending over. I think I can get used to this.
New/Unused 2 Post Car Lift (A61166)
New/Unused 2 Post...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
EXCAVATOR RIPPER (A58214)
EXCAVATOR RIPPER...
Ferris Z3X Lawn Mower (A61166)
Ferris Z3X Lawn...
2008 Kenworth W900 Grapple/Storm Truck, VIN # 1NKWX40X68J221827 (A61165)
2008 Kenworth W900...
