om21braz
Veteran Member
Anyone else on here ever had a Stihl that flat had to warm up before running? I've got an 028 that is about 25 years old - used minimally over the years, but it has always been cold natured from day one. You get it started with choke on (even if it's 90 deg. outside), let it idle for 5 minutes or so, then and only then can you cut choke off and operate as normal. It's been adjusted on by many with no success. Not a big issue, just curious if anyone else has had this problem and managed to cure it. No other piece of Stihl equipment I have or have had is like this.
