clutch questions..
/ clutch questions.. #1
psuedofarmer
new hampshire
Kioti DK55 Cab, 3 NHs (from 40-90HP)
this goes along the lines of a stupid question (although i know there are really no stupid ones!):
just when does the clutch have to be engaged?
i know that it has to be engaged when changing gears, what about forward/reverse, changing from Low/Med/High and going from 2 to 4 wheel drive?
i believe i know the answer to this - but perhaps someone can put my mind at ease..
pf
DK55c
/ clutch questions.. #2
I believe the manual calls for using the clutch to do all of those. Of course, you have a different tractor than I, but my manual says to use the clutch for 2/4WD changes, but if you're sitting still, and you should be, it will change without the clutch in, as will the range selector on mine. F/R shuttle requires the clutch on that model, but you don't have to come to a complete stop. John
thanks - i read the manual in the wee-hours of the morning - and i now recall it does say exactly what you described.
pf
/ clutch questions.. #4
How about disengaged instead of engaged? /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif
/ clutch questions.. #5
</font><font color="blue" class="small">( How about disengaged instead of engaged? )</font>
you're sooo right Bird. /forums/images/graemlins/grin.gif John
/ clutch questions.. #6
I use it for everyhting just because. When changing ranges or 2-4wd. stop and use the loader to raise the front wheels off the ground . This allows for real easy transitions. You do not have to be at a full stop for the forward - reverse changes .Did my first fuel cannister change on my DK 55 today and it runs real smooth. Funny how things get a bit funky without notice.
/ clutch questions.. #7
one of the most important things to remember about the clutch on any machine is ,---- GET YOUR FOOT OFF THE PEDAL when you are NOT actually using it.
The pedal makes for a comfortable foot rest. That ain't what its for.
Do not "feather" the clutch when digging. Choose a lower gear and GET YOUR FOOT OF THE PEDAL.
Proper use of the clutch will result in many thousands of hours of use. Improper use will result in just a few hours of use and many $$$$ in replacement.
Have fun and be careful virgil
2004 John Deere 8320 (A63688)
2004 John Deere...
John Deere 2210 Field Cultivator 43' (A63688)
John Deere 2210...
3147 (A63117)
3147 (A63117)
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
QA Sweeper (A64126)
QA Sweeper (A64126)
New/Unused Electric Winch (A65583)
New/Unused...
