clutch questions..
/ clutch questions.. #1
psuedofarmer
new hampshire
Kioti DK55 Cab, 3 NHs (from 40-90HP)
this goes along the lines of a stupid question (although i know there are really no stupid ones!):
just when does the clutch have to be engaged?
i know that it has to be engaged when changing gears, what about forward/reverse, changing from Low/Med/High and going from 2 to 4 wheel drive?
i believe i know the answer to this - but perhaps someone can put my mind at ease..
pf
DK55c
/ clutch questions.. #2
I believe the manual calls for using the clutch to do all of those. Of course, you have a different tractor than I, but my manual says to use the clutch for 2/4WD changes, but if you're sitting still, and you should be, it will change without the clutch in, as will the range selector on mine. F/R shuttle requires the clutch on that model, but you don't have to come to a complete stop. John
thanks - i read the manual in the wee-hours of the morning - and i now recall it does say exactly what you described.
pf
/ clutch questions.. #4
How about disengaged instead of engaged? /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif
/ clutch questions.. #5
</font><font color="blue" class="small">( How about disengaged instead of engaged? )</font>
you're sooo right Bird. /forums/images/graemlins/grin.gif John
/ clutch questions.. #6
I use it for everyhting just because. When changing ranges or 2-4wd. stop and use the loader to raise the front wheels off the ground . This allows for real easy transitions. You do not have to be at a full stop for the forward - reverse changes .Did my first fuel cannister change on my DK 55 today and it runs real smooth. Funny how things get a bit funky without notice.
/ clutch questions.. #7
one of the most important things to remember about the clutch on any machine is ,---- GET YOUR FOOT OFF THE PEDAL when you are NOT actually using it.
The pedal makes for a comfortable foot rest. That ain't what its for.
Do not "feather" the clutch when digging. Choose a lower gear and GET YOUR FOOT OF THE PEDAL.
Proper use of the clutch will result in many thousands of hours of use. Improper use will result in just a few hours of use and many $$$$ in replacement.
Have fun and be careful virgil
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
1999 INTERNATIONAL 4700 4X2 FLATBED DOVETAIL TRUCK (A65057)
1999 INTERNATIONAL...
60 Gal Spray Rig (A64912)
60 Gal Spray Rig...
2016 Nissan Frontier Crew Cab Pickup Truck (A66736)
2016 Nissan...
BAMA BUILT 7x16 Hybrid Dump Trailer (A68134)
BAMA BUILT 7x16...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
