2022 Kioti CK2610se PTO will not disengage
/ 2022 Kioti CK2610se PTO will not disengage #1
Bootlick
Kioti ck2610 se
2022 CK2610se cab 600hrs
I have been searching all over for a solution.
I will try to explain my pto issue. I hope someone has a solution
-When I start the tractor pto remains off
-place tractor in gear Low/med/high pto engages pto light comes on
-PTO will remain off if the auto pto function is on and 3 point hitch is raised
The pto is fully engaged not just an idle spin
Things i have done so far - PTO switch replaced - solenoid replaced- replaced relay switch
My thought is that this could be an electrical issue because the auto shut off works when i raise the 3pt hitch but I have run out of ideas on what it could be :p any thoughts ?
Bump
/ 2022 Kioti CK2610se PTO will not disengage #3
Looks like the parts cannon have been fired to no avail. From your description, I'll say you have a short somewhere. Probably related to whatever sensor is on the range lever.
I can only suggest that you follow the wiring and take a close look at it. Check for any damage, rubbing, etc.
Thats my guess Probably mice ty
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
2014 Ford Escape Titanium SUV (A59231)
2014 Ford Escape...
UNUSED IRMC HIGH END MASSAGE CHAIR (A60432)
UNUSED IRMC HIGH...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
UNUSED ZJG ZJ-13 EXCAVATOR (A60430)
UNUSED ZJG ZJ-13...
