Clutch Question....
/ Clutch Question.... #1
WEJ
Garrett County, Maryland
Montana 4340
I now have 100 hrs. on my 4340cab. My question is about the clutch. Ever since day one it has not been smooth. I must pull the throtle all the way down to go forward and even then I encounter the 'Jumps" some times. The tractor just shakes and jumps like it would like to explode, instead of going forward!! I have learned to start in a lower gear and use the foot thortle to get going, but I think the clutch should be a lot smoother.... I can not "feather" the clutch to get a smooth start. Going in reverse I do not have this problem. Any suggestions ... Has anyone else had this experience?
/ Clutch Question.... #2
It sounds like you have a clutch from a dragster, no play, I'd suspect a problem with the clutch lining.
/ Clutch Question.... #3
Call your dealer. The fact that you say it doesn't do it when backing up, but going forward leads me to think it is the cab mounts. There were some that had cab shudder issues and there is a harder rubber mount available that will solve the problem.
Ken
Hey Montanaman,
Tell me more about this "Cab Stutter" thing. When I first got my tractor the rear cab mount bolt had some up and down play in it. It would bang like metal on metal.... I took it back to the dealer and they just put a thicker bolt in and it solved the up and down movement problem... but Stutter is a good way to describe what I am experiencing. When I contact my deal is there any recalls or bulletins from Montana I should have him research?
Thanks,
Bill
/ Clutch Question.... #5
Ken is right. It is most likely the rear cab mounts. Some were a bit soft but they have a much harder neoprene one that you switch out and all is good. Seen this a couple of time. No big deal, your dealer should be able to replace them fairly quickly and easily.
Maka
Thanks Ken & Maka,
I sure did not think I was having a Cab issue!!!:confused: I was sure I was in for a LARGE tear-down. Like I said before I did have a problem with the rear cab mounts not being tight when I first got the tractor and I was having issues getting it to start to move forward from a stop smoothly. Never working with a cab or desiel tractor before, I thought it was just me and I was not used to the clutch. I did wonder though, way it was not a problem when going in reverse. Anyway, after the holidays I am going to contact my dealer and tell him what both of you have said and let him try to get me going smoothly!!:cool:
Just for my own information though.... What is going on here that the cab mounts can effect my clutch engagement so much???
Bill
/ Clutch Question.... #7
Bill
It really isn't an issue with the clutch at all but when you let the clutch out, the cab rocks back and then rebounds giving the shudder.
Years back when working on cars, I almost wrecked a car because the customer failed to inform me his seat mount was broken. He kept the car as clean as a bird cage and I didn't even want to touch the steering wheel. When I let the clutch out, the seat flipped back and took my foot off of the gas, this caused the car to stop and the seat fell back down and I smashed the gas again. This cycle happened a half a dozen times in about two seconds until I grabbed the wheel hard enough to hold the seat still. I think that's what the cab is doing in a much less violent way! The clutch starts the tractor moving and the cab will shudder for a short bit till it settles on the mounts.
New mounts should fix it 100%.
Ken
Update on my 'Cab Stutter' situation.... I just got my tractor back today from the dealer. He only had it for a day and switched out the rear cab mounts.... The problem is, I still have the cab stutter.... I can see no difference.... I have called Montana and they are looking into it. I will keep everyone posted.... but for now I am still looking for help here..... Is anyone else having this problem? When I try to engage the clutch and go forward the cab jumps and shakes like it want to fly off the tractor!!! HELP!!!
Did they fix my clutch problem..... I have been working with Montana and my dealer for several months now on the stutter problem.... First they put in new rear cab mounts..... Did not help..... Next they put in a new clutch..... A NEW CLUTCH!! Did not help.... Today then put in new front cab mounts..... PROBLEM SOLVED!!!! SOLVED!!! It worked. Apparently the front mounts were too soft.... As of today the stutter is GONE!!! I am one happy Montana owner.... Yes I did have to keep after them, but it has payed off for me. I have looked at a lot of other tractors, here in the last few months, but I still don't see any that are built as heavy as my Montana or has as many options. Like I said, at this time with 200 hours on the tractor, I am very happy... and during those 200 hours I have not babied it all... 8 foot brush hog.... Lots of road grading.... Many trees pulled.... With the stutter problem gone I am now looking forward to years of happy tractoring...
/ Clutch Question.... #11
Great. We were pretty sure it was the soft mounts but that was something we only saw on the rear here and even then it was rare. I am glad you got it taken care of and happy tractoring.
Maka
/ Clutch Question.... #12
That's great
As a new Montana owner, I was curious as to their follow-up.
Thanks
Roland
/ Clutch Question.... #13
Now the new clutch will probably go out and cause the tractor to stutter and you will be having mounts made out of 1/2 plate steel
/ Clutch Question.... #14
Congrats on the fix. Glad they stood in there and worked with you to fix the problem even if it took additional reminding. I am glad you are open minded enough to realize you really like the tractor and will like it even more now that it is fixed. Its nice to hear someone praise the tractor even though for a long time it was a real pain in the butt. It would be realy easy for you to bash the equipment call it junk and be a mad man on a mission. I wish there were more customers like you!
Hey Tractech,
I have found that yelling and going crazy hardly ever works to get you what you want. Now, I had made up my mind I would not accept the tractor the way it was... If nothing else I wanted a new tractor from Montana... and had make that point with Montana management. I had told them from the beginning that all I wanted was for my tractor to be right. Hard to argue with that... but I also knew I had to give them the chance to make that happen.
I also looked at every other tractor and dealer around... bottom line is I did not see another tractor I liked as much.... even when mine had the 'Shakes!!' So I was glad that the problem was solved.
I think the Montana is a GREAT tractor.... and I do have a dealer less than 10 miles away... and as we all know a good dealer is VERY important with any kind of purchurse...
/ Clutch Question.... #16
Hey WEJ
Great name for the tractor "Shakes"
[/QUOTE]I also looked at every other tractor and dealer around... bottom line is I did not see another tractor I liked as much.... even when mine had the 'Shakes!!' So I was glad that the problem was solved.
I think the Montana is a GREAT tractor.... and I do have a dealer less than 10 miles away... and as we all know a good dealer is VERY important with any kind of purchurse...[/QUOTE]
Bestway 750 Sprayer (A66285)
Bestway 750...
New Holland Super Hayliner 68 - Small Square Baler (A66408)
New Holland Super...
2013 International WorkStar 7500 29Yd. Side Loader Garbage Truck (A64194)
2013 International...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2018 Chevrolet Suburban 4x4 SUV (A64557)
2018 Chevrolet...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
