close call
/ close call #1
rdbrumfield
Western Washington
5300 JD 4X4
I was greasing a heavy-haul lowboy last Fri. I had greased the under parts and was finishing up in the engine compartment. The steering shaft comes out of the firewall at a faily steep angle and I asked the driver to give the wheel a turn so that I could get on the zerk. He responded with "sure, I will fire it up". I was standing between the front tire and the bumper at the time and stepped out to the side. He hit the key while standing on the running board. It sarted in gear and by the time he turned off the key it had shoved over a work table and it stopped just before going through the shop wall. The hood was open and it broke the bug deflector. The shop table I repaired easily. We were very lucky. The thing is that there were several things that led up to this accident, as most are caused by small events leading up to a finally. (1) he left the brakes off to adjust them. (2) there was a plastic sack on the seat and he couldn't see the shift lever. (3) and most important, he didn't get in, sit in the seat, depress the clutch, check the gearing, and do a proper start.
Folks, these little shortcuts are just not worth it. Over the years the manufacturers have made lockouts on our tranny, pto, seats and just about everything they can think of to make our world be a bit safer. In the end it really up to us. Be safe and happy tractoring.
/ close call #2
Glad to hear you made it out of that one ok. You are right.. the shortcuts are NOT worth it. I have made it a point to follow all safety procedures with my tractor and any other equipment. Reading this forum will make anyone step back and think about what they are doing.
2019 Chevrolet Express Box Van, VIN # 1GB0GRFP7K1370206 (A65563)
2019 Chevrolet...
2018 Chevrolet Tahoe SUV (A64194)
2018 Chevrolet...
2011 Ford F-350 Service Truck, VIN # 1FDRF3GT8BEA38908 (A65563)
2011 Ford F-350...
429888 (A61165)
429888 (A61165)
CASE 610 Sprayer System 2000 Gallons (A63688)
CASE 610 Sprayer...
2003 Toyota Tundra Extra Cab Pickup (A62613)
2003 Toyota Tundra...
