Clicking Relay
/ Clicking Relay #1
Benny Blue
Alberta
Montana R3644
When walking past the tractor today I heard a clicking coming from the instrument panel today so i figured i left the key turned on... i checked and the key was off so i pulled it out and the clicking continued... a click every 5sec or so??? Sounded like a relay clicking.
I pulled off the instrument panel cover and sure enough found the relay that was constantly clicking. Looking at the parts breakdown it looks like there could be 3 relays attached to this bracket, but i've pointed out the one that is in the position indicated in the breakdown. It's description is simply "Relay". Anyone know the purpose of this relay and if it is constantly clicking, even with the key turned off and pulled out, any suggestions what the issue may be?
Screen Shot 2020-11-13 at 12.26.44 PM.pngScreen Shot 2020-11-13 at 12.31.14 PM.png
/ Clicking Relay #2
I don't know your tractor at all but from the list of relays I don't see a fuel cutoff relay. It should not be constantly clicking, though. Something is causing it to keep cycling.
/ Clicking Relay #3
Take the relay out and see what works and doesn't , Then go from there........
/ Clicking Relay
So far it only seems like the relay controls the left/right signal lights. They are the only thing I notice not working if I unplug it and start up the tractor.
/ Clicking Relay #5
Anything get wet?
/ Clicking Relay #6
Switch broken....... full of water shorting out....:confused3: flasher stuck..
/ Clicking Relay
It’s parked under a well sheltered lean-to and wasn’t out in any rain.
I’ll take a closer look at the switch today, but if it is just the relay itself then it’s only $25... and about 3 weeks out. Which isn’t bad if it’s only for the signal lights.
The supplier even suggested taking it to an auto part supplier to see if they can match it.
/ Clicking Relay #8
Parts stores should have a Bosch relay in stock...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
Preliminary Listing / Full Catalog Coming Soon! (A62180)
Preliminary...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
Four (4) John Deere 8R Front Fenders (A65640)
Four (4) John...
