Cleaning rusty stuff
/ Cleaning rusty stuff #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
I have a bunch of rusty railroad stuff I want to clean up for the garage. I have to do a bit of decorating. :)
What is the best thing to use to clean rust of stakes and other items before you paint them.
Thanks.
/ Cleaning rusty stuff #3
why take the rust off?
why not give a quick wire brushing to knock off loose stuff then give it a coat of "rust converter" to use as your primer?
/ Cleaning rusty stuff #4
I use a 6" wire wheel on my bench grinder for rust removal on anything of a size and shape that makes the wire wheel use possible. I used to have a glass bead blasting cabinet (like a sandblast cabinet) that worked very well, also.
/ Cleaning rusty stuff #5
I've been using the electrolysis method for a few years now, it really works great. I have the battery tray from my 4200 in there right now.:D
M.D.
/ Cleaning rusty stuff #6
I agree with all the other posters. But it also depends on what kind of rust - surface or deep, and what kind of finish you want to have on the stuff when your done.
When I gutted and remodeled my old farm house, all the door hinges were rusty. I had to sand blast them all to get the rust out prior to repainting them. When I redid some of the old door knobs, which were porcelain with the metal bar, I just lightly scuffed them with some fine sandpapper and resprayed them.
When I put up some old (1902) PA license plates in my garage, I didn't want to do much to them. I sprayed the backs with rustx, then sealed the whole thing with a clear shellac with about 3 coats. Not enough to make it appear shiny, but enough to seal it completely.
Good luck. You can also buy biscuits for use on an die grinder in very fine or very coarse grits. I found that they work well in some tight spaces. Sometimes wire wheels work best on a bench grinder or on a cordless drill, depending on how big the item is. Oh, and be careful. Some of that old stuff has lead base paint. Lead is cumulative over the course of your life.
/ Cleaning rusty stuff #7
POR-15 (Google it!) has a 'paint' that works well with rust, as it uses it as some sort of bonding agent. I think the only pre-requisite is that you wire brush it first to knock off all the really loose stuff.
Normally this stuff is UV sensitive, so if it was exposed you'd add another layer of paint of your choice. Given that this is going to be indoors, this might work very well for you.
/ Cleaning rusty stuff #8
Nice dog ya got there...what's the pedigree? One of Ginny's dogs?
/ Cleaning rusty stuff #9
M.D.
Let me guess...your original battery ate the battery tray, oil cooler and anything else that got in its way like it did mine.
/ Cleaning rusty stuff #10
I noticed in the link to electrolysis cleaning they used sodium carbonate, sold as washing soda to mix up the electrolyte. If one can't find "washing soda" it can also be bought as Ph Adder in pool supply departments. I discovered this because we buy Brew-Rite coffee pot cleaner and found it is also sodium carbonate...one can buy pounds of it as pool Ph Adder for the same price as ounces of Brew-Rite ;)
/ Cleaning rusty stuff #11
Thanks.
Mornin Matthew,
IMO the best way with the least amount of mess is the wire wheel on a right angle grinder. When I can I use the bead blaster at work, but I realize that most people dont have that option. But it sure makes short work of anything rusty. I generally knock of the bulk with a wire hand brush and then finish it in the bead blast cabinet. The braided wire wheels that go on the right angle grinder do a terrific job also !
BTW a needle scaler is also a good idea, I just havent gotten around to buying one yet !;)
2022 EZ-GO ELITE...
2025 TP25 25in Hydraulic Post Puller Skid Steer Attachment (A64553)
2025 TP25 25in...
1143 (A63745)
1143 (A63745)
2016 TAKEUCHI TB240 EXCAVATOR (A65053)
2016 TAKEUCHI...
2022 Sany SY35U Mini Excavator (A64553)
2022 Sany SY35U...
2007 JLG 600HJ 60ft 4x4 Articulating Boom Lift (A64553)
2007 JLG 600HJ...
