CK3510HST Lane shark
/ CK3510HST Lane shark #1
tallfreak
North Mississippi
na
Does anyone have any experience with a lane shark on a CK3510HST? I have the 3rd function kit, but I dont know if it has enough flow. I also have the auxiliary hydraulics, but I don't have a detent lever so I would have to hold it or rig something up to keep it flowing.
Does anyone know the flow on the factory 3rd function connections? It looks like I need a minimum of 8.5gpm.
/ CK3510HST Lane shark #2
I have the same machine. I don't know the flow on the 3rd function, but I am reasonably sure you do not want to use it, nor is it intended for a 100% duty cycle with as high a power demand as something like the lane shark has. It would probably get your hydraulic fluid really, really hot.
Better off using a power pack on your PTO with some long hydraulic lines, I think?
/ CK3510HST Lane shark #3
Yep. Recommend the power pack to go with it.
Kioti confirmed its 6.8 GPM on the rear remotes and the third function.
Why is overheating not a concern talking to Lane Shark? They recommend using the third function.
How can the rear remotes run log splitters and stump grinders and backhoes without overheating?
/ CK3510HST Lane shark #5
Probably have to look at the flow rates and duty cycles for each implement you plan on running. The Lane Shark seems to be a pretty heavy user of hydro fluid. Log splitters....most likely less.
/ CK3510HST Lane shark #6
Not to mention that you would likely have to hold the button in the whole time you are cutting?
(INOP) JOHN DEERE 7700 PRECISION CUT REEL MOWER (A60430)
(INOP) JOHN DEERE...
2017 Kawasaki Mule 4010 4x4 Rescue Gas Utility Cart (A59228)
2017 Kawasaki Mule...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
UNUSED SDLANCH SDLC2030FT-20'X30' CARPORT (A60432)
UNUSED SDLANCH...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
2020 Ford Ecosport 4WD SUV (A59231)
2020 Ford Ecosport...
