CK3510HST Lane shark
/ CK3510HST Lane shark #1
tallfreak
North Mississippi
na
Does anyone have any experience with a lane shark on a CK3510HST? I have the 3rd function kit, but I dont know if it has enough flow. I also have the auxiliary hydraulics, but I don't have a detent lever so I would have to hold it or rig something up to keep it flowing.
Does anyone know the flow on the factory 3rd function connections? It looks like I need a minimum of 8.5gpm.
/ CK3510HST Lane shark #2
I have the same machine. I don't know the flow on the 3rd function, but I am reasonably sure you do not want to use it, nor is it intended for a 100% duty cycle with as high a power demand as something like the lane shark has. It would probably get your hydraulic fluid really, really hot.
Better off using a power pack on your PTO with some long hydraulic lines, I think?
/ CK3510HST Lane shark #3
Yep. Recommend the power pack to go with it.
Kioti confirmed its 6.8 GPM on the rear remotes and the third function.
Why is overheating not a concern talking to Lane Shark? They recommend using the third function.
How can the rear remotes run log splitters and stump grinders and backhoes without overheating?
/ CK3510HST Lane shark #5
Probably have to look at the flow rates and duty cycles for each implement you plan on running. The Lane Shark seems to be a pretty heavy user of hydro fluid. Log splitters....most likely less.
/ CK3510HST Lane shark #6
Not to mention that you would likely have to hold the button in the whole time you are cutting?
METAL SAW HORSE (A68842)
METAL SAW HORSE...
2021 Unused Paladin MD60SC 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
2021 Unused...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2015 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2015 FREIGHTLINER...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2006 MACK CHN613 DAYCAB (A67714)
2006 MACK CHN613...
