CK3510HST Lane shark
   / CK3510HST Lane shark #1
tallfreak
North Mississippi
na
Does anyone have any experience with a lane shark on a CK3510HST? I have the 3rd function kit, but I dont know if it has enough flow. I also have the auxiliary hydraulics, but I don't have a detent lever so I would have to hold it or rig something up to keep it flowing.
Does anyone know the flow on the factory 3rd function connections? It looks like I need a minimum of 8.5gpm.
   / CK3510HST Lane shark #2
I have the same machine. I don't know the flow on the 3rd function, but I am reasonably sure you do not want to use it, nor is it intended for a 100% duty cycle with as high a power demand as something like the lane shark has. It would probably get your hydraulic fluid really, really hot.
Better off using a power pack on your PTO with some long hydraulic lines, I think?
   / CK3510HST Lane shark #3
Yep. Recommend the power pack to go with it.
Kioti confirmed its 6.8 GPM on the rear remotes and the third function.
Why is overheating not a concern talking to Lane Shark? They recommend using the third function.
How can the rear remotes run log splitters and stump grinders and backhoes without overheating?
   / CK3510HST Lane shark #5
Probably have to look at the flow rates and duty cycles for each implement you plan on running. The Lane Shark seems to be a pretty heavy user of hydro fluid. Log splitters....most likely less.
   / CK3510HST Lane shark #6
Not to mention that you would likely have to hold the button in the whole time you are cutting?
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
2018 Chevrolet Silverado 2500HD Crew Cab Service Truck (A56858)
2018 Chevrolet...
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
2014 Ford Fusion Passenger Car, 2.5L Engine - Only 90,875 Miles (A56438)
2014 Ford Fusion...
2018 Chevrolet Colorado Pickup Truck, VIN # 1GCHSBEA6J1312961 (A57453)
2018 Chevrolet...
