Ck3510HSE Fuel Filter?
/ Ck3510HSE Fuel Filter? #1
pcustoms
VT
Kioti CK3510SE
Tractor is a 2020 CK3510HSE (hydrostatic, SE, open cab)
Seems to be a lot of reference for the F6800-16411 fuel filter, including my own manual.
My tractor has a clear bowl and water sensor on the bottom. Looks like EH35-0011A based on what I was able to get from a cellphone pic (side with numbers is towards engine).
Why is this so damn hard to find?
/ Ck3510HSE Fuel Filter? #2
Because there isn't a ton of info out there about the Kioti's yet...
Not sure if it will be much help, as there may not be one nearby or they may suck..
I had an issue finding a freeze plug sleeve for the block heater I installed in my 3510. I ended up stopping at the local Bobcat dealer and used their part.
All they needed to know was the model number of the tractor. Bobcat equivalent is a CT2035 or CT2535(cabbed) for the CK3510.
I did find Bobcat provides better instructions with their parts.
Hope that helps.
-Sal
/ Ck3510HSE Fuel Filter? #4
This is the one you need, I believe. I have the same as you:
or this place claims to have the same one, but pic doesnt match?
/ Ck3510HSE Fuel Filter? #5
If you are looking for the whole Filter Kit, look for the 'Stage 5' versions. As far as I can tell, they have 2 different Air Filters depending on when it was built (serial range):
This is an OEM filter kit which includes the air filter TC26-1869A, engine oil filter E6201-32443, fuel filter EH35-0011A, hydraulic filter T2185-38031, HST filter T5855-46531. The distinguishing difference is that the air filter cover is held on with one plastic clip. The fuel filter has a clear bowl on the bottom
and,
Not sure what Air Filter you have.
Bump.
@MichiganIron ?
/ Ck3510HSE Fuel Filter? #7
If you have the single Orange air filter housing clip and the Clear Bowl fuel filter, the Nolts Power kit I listed is the correct kit.
You have exactly the same tractor as mine - a 2020 CK3010HSE - and the manual is incorrect.
If you have a dealer close, you can get it from there so you can see and compare first.
/ Ck3510HSE Fuel Filter? #8
Hope that helps.
-Sal
So, Shiner has a Bobcat dealer....All I need is give him my NX4510HST number for my parts????
Dang 10 minute drive better then 1.5 hour drive to Kioti dealer....TY for that....!
I don't recall an orange air filter clip, but I do have the clear bowl.
No dealers super close, so trying to order online
/ Ck3510HSE Fuel Filter? #10
Main thing is that its a single clip and not the normal 3.
So here's the weird thing, the air filter has 3 clips...
But this is my fuel filter:
I'm not following how the 2 are connected?
I ended up buying the EH35-0011A from
$97 all in, shipped same day. Unless USPS bobbles it should have it Monday afternoon
/ Ck3510HSE Fuel Filter? #13
In that case, then this is the kit you need:
"This is an OEM filter kit which includes the air filter E7230-11081 or TC26-1225A, engine oil filter E6201-32443, fuel filter EH35-0011A, hydraulic filter T2185-38031, HST filter T5855-46531. The distinguishing difference is that the air filter cover is held on with three metal clips. The fuel filter has a clear bowl on the bottom."
/ Ck3510HSE Fuel Filter? #14
Save those part numbers.
Oh, you're talking about a kit.
I don't need all the other filters at this time, just was stuck on finding the fuel filter.
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2014 Chevrolet Equinox SUV (A64557)
2014 Chevrolet...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
