Ck3510HSE Fuel Filter?
/ Ck3510HSE Fuel Filter? #1
pcustoms
VT
Kioti CK3510SE
Tractor is a 2020 CK3510HSE (hydrostatic, SE, open cab)
Seems to be a lot of reference for the F6800-16411 fuel filter, including my own manual.
My tractor has a clear bowl and water sensor on the bottom. Looks like EH35-0011A based on what I was able to get from a cellphone pic (side with numbers is towards engine).
Why is this so damn hard to find?
/ Ck3510HSE Fuel Filter? #2
Because there isn't a ton of info out there about the Kioti's yet...
Not sure if it will be much help, as there may not be one nearby or they may suck..
I had an issue finding a freeze plug sleeve for the block heater I installed in my 3510. I ended up stopping at the local Bobcat dealer and used their part.
All they needed to know was the model number of the tractor. Bobcat equivalent is a CT2035 or CT2535(cabbed) for the CK3510.
I did find Bobcat provides better instructions with their parts.
Hope that helps.
-Sal
/ Ck3510HSE Fuel Filter? #4
/ Ck3510HSE Fuel Filter? #5
If you are looking for the whole Filter Kit, look for the 'Stage 5' versions. As far as I can tell, they have 2 different Air Filters depending on when it was built (serial range):
This is an OEM filter kit which includes the air filter TC26-1869A, engine oil filter E6201-32443, fuel filter EH35-0011A, hydraulic filter T2185-38031, HST filter T5855-46531. The distinguishing difference is that the air filter cover is held on with one plastic clip. The fuel filter has a clear bowl on the bottom
and,
Not sure what Air Filter you have.
Bump.
@MichiganIron ?
/ Ck3510HSE Fuel Filter? #7
If you have the single Orange air filter housing clip and the Clear Bowl fuel filter, the Nolts Power kit I listed is the correct kit.
You have exactly the same tractor as mine - a 2020 CK3010HSE - and the manual is incorrect.
If you have a dealer close, you can get it from there so you can see and compare first.
/ Ck3510HSE Fuel Filter? #8
Hope that helps.
-Sal
So, Shiner has a Bobcat dealer....All I need is give him my NX4510HST number for my parts????
Dang 10 minute drive better then 1.5 hour drive to Kioti dealer....TY for that....!
I don't recall an orange air filter clip, but I do have the clear bowl.
No dealers super close, so trying to order online
/ Ck3510HSE Fuel Filter? #10
Main thing is that its a single clip and not the normal 3.
So here's the weird thing, the air filter has 3 clips...
But this is my fuel filter:
I'm not following how the 2 are connected?
I ended up buying the EH35-0011A from
$97 all in, shipped same day. Unless USPS bobbles it should have it Monday afternoon
/ Ck3510HSE Fuel Filter? #13
In that case, then this is the kit you need:
"This is an OEM filter kit which includes the air filter E7230-11081 or TC26-1225A, engine oil filter E6201-32443, fuel filter EH35-0011A, hydraulic filter T2185-38031, HST filter T5855-46531. The distinguishing difference is that the air filter cover is held on with three metal clips. The fuel filter has a clear bowl on the bottom."
/ Ck3510HSE Fuel Filter? #14
Save those part numbers.
Oh, you're talking about a kit.
I don't need all the other filters at this time, just was stuck on finding the fuel filter.
1997 GMC GMT-400 SINGLE CAB TRUCK (A62130)
1997 GMC GMT-400...
40' CONTAINER (A62131)
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2009 John Deere Z925A Zero Turn (A63116)
2009 John Deere...
1770 (A58375)
1770 (A58375)
John Deere 7230 (A62180)
John Deere 7230...
