CK30 Widening Track?
/ CK30 Widening Track? #1
mrutkaus
Platinum Member
15 mi. N. of Winchester VA
Kioti CK30HST, Kubota BX-1500,
I've read here about widening the track of the CK30 with ag tires. Looking at mine I can't see how, maybe it is already as wide as possible.
How do you do this, just take the wheel off and reverse it?
Thanks,
Mike
/ CK30 Widening Track? #2
The ag tire wheels are 2 piece. The outside ring can be seperated from the inside dish.
If you look at the lugs that the dish hooks to you will see that it will make a difference which side the dish is mounted to them and also the dish and outside ring are offset from centerline differently.
The tractor in the pic is a CK series set as wide as possible.
BTI
I like that! Not sure if I would have figured it out!
In your experience how much less tippy does it make it? Any downside?
Thanks a lot for the 1,000 words.
Mike
/ CK30 Widening Track? #4
BAH! BTI, you forgot to put on the left side 3ph arm stabilizer.
I've had to weld my right side stabilizer together a few times.
/ CK30 Widening Track? #5
Regarding widening tracks on CK tractors: at some point I saw a note that Kioti CK and Kubota B series wheels were interchangeable. I don't know if that is true. However, if it is, then Kubota sells a spacer kit that widens the track of the B3030 (so it can accept chains). That would widen the track by a few inches total which should be very helpful on slopes. You could also have custom spacers machined but for much more money.
/ CK30 Widening Track? #6
Highbeam,
Nope customer came in and needed it, gave it to the customer and ordered another. :D
Anything else....:p:p
BTI
/ CK30 Widening Track? #7
mrutkaus, no downside unless you have a gate that's not wide enough to get through.
island, I do know that the old L3000 and LK3054 wheels would interchange.
I would just measure them and see.
I'd bet they will, but would want to make sure before ordering something.
BTI
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
2017 Mack Semi (A64047)
2017 Mack Semi...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
Ford Pickup Truck Bed (A61573)
Ford Pickup Truck...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2015 ISUZU NQR 4X2 DEBRIS TRUCK (A59911)
2015 ISUZU NQR 4X2...
