CK30 Widening Track?
/ CK30 Widening Track? #1
mrutkaus
Platinum Member
15 mi. N. of Winchester VA
Kioti CK30HST, Kubota BX-1500,
I've read here about widening the track of the CK30 with ag tires. Looking at mine I can't see how, maybe it is already as wide as possible.
How do you do this, just take the wheel off and reverse it?
Thanks,
Mike
/ CK30 Widening Track? #2
The ag tire wheels are 2 piece. The outside ring can be seperated from the inside dish.
If you look at the lugs that the dish hooks to you will see that it will make a difference which side the dish is mounted to them and also the dish and outside ring are offset from centerline differently.
The tractor in the pic is a CK series set as wide as possible.
BTI
I like that! Not sure if I would have figured it out!
In your experience how much less tippy does it make it? Any downside?
Thanks a lot for the 1,000 words.
Mike
/ CK30 Widening Track? #4
BAH! BTI, you forgot to put on the left side 3ph arm stabilizer.
I've had to weld my right side stabilizer together a few times.
/ CK30 Widening Track? #5
Regarding widening tracks on CK tractors: at some point I saw a note that Kioti CK and Kubota B series wheels were interchangeable. I don't know if that is true. However, if it is, then Kubota sells a spacer kit that widens the track of the B3030 (so it can accept chains). That would widen the track by a few inches total which should be very helpful on slopes. You could also have custom spacers machined but for much more money.
/ CK30 Widening Track? #6
Highbeam,
Nope customer came in and needed it, gave it to the customer and ordered another. :D
Anything else....:p:p
BTI
/ CK30 Widening Track? #7
mrutkaus, no downside unless you have a gate that's not wide enough to get through.
island, I do know that the old L3000 and LK3054 wheels would interchange.
I would just measure them and see.
I'd bet they will, but would want to make sure before ordering something.
BTI
Adams Weight Hopper (A63688)
Adams Weight...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
Safety Basket Forklift Attachment (A61572)
Safety Basket...
Towable Pipe Road Crossing Trailer (A63689)
Towable Pipe Road...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
CATERPILLAR D5K2 LGP CRAWLER DOZER (A64279)
CATERPILLAR D5K2...
