CK30 has it's limits.
/ CK30 has it's limits. #1
IXLR8
Elite Member
Eastern Shore- Virginia
Kioti DK-40SE
The original owners of our home had one of those large 6ft satellite dish's. A subsequent owner turned the mounting post into a swing set. SWMBO decided that she wanted the 'swing' moved out of the side yard and into her garden. No problem... I though... just dig up the base, dig a hole in the garden, plant base... instant swing. :) When I got done digging around the base... I found it was 2.5ft in diameter and 4ft deep!!! I tried to lift it out... I could not budge it! :( Quick calculations show it weighs about 2700lbs!! :eek: No wonder I can't move it. I just cut the pole off, made a bigger hole and buried it.
Looks like I am going to be building a wooden swing now.
/ CK30 has it's limits. #2
A man's got to know his (and his machines) limitations.
They certainly didn't want that thing to blow down in the wind:)
Good job.
Tom
/ CK30 has it's limits. #3
I am still trying to figure out how they made a swing out of a single 6' pole. Sounds painful! :eek:
There was another pole bolted to the top of that one with a cross bar added across the top. This made it 'T' shaped, then the swings hung from the cross bar.
/ CK30 has it's limits. #5
... I could not budge it! :( Quick calculations show it weighs about 2700lbs!! :eek: No wonder I can't move it. .
Are you trying to talk yourself into a DK40se with 2700lb lift capacity to full height so you can lift that thing and dump it over your fence into the neighbor's yard?:rolleyes:
That is the first thing I thought of after I crunched the weight numbers. All you have done with your DK40. Neighbor has a big enough tractor so he could pick it up and give it back to me. I would have had him move it... but I just didn't want to deal with something that big... and if SWMBO ever wanted to move it again.. I didn't want to have to depend on him to move it. So I burried it and ordered some lumber to build a swing. I think a wood swing will look better anyway.
/ CK30 has it's limits. #8
LOL. I too had a 6' satelite dish in my yard when I bought my house. Before I had my tractor, I wrapped a strap around the top of the pole and thought I would pull it out with my pickup. It just bent the pole until it touched the ground. The first day I had my backhoe, I went after the pole. After digging for an hour, I had exposed a 55 gallon drum filled with concrete with about a foot more concrete poured over the top. After messing with it for a while, I came to the conclusion to dig a bigger hole and bury it was my best (only) option.
/ CK30 has it's limits. #9
I have a DK40se and am sorry I didn't get the DK55, but then if I had the 55 I'd want the 65 or 90.
Actually, I'm happy with the DK40 with my only complaint is that I can't really pull a 3 bottom plow.
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
2020 HYDREMA 922GHM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA...
1996 International Paystar 5000 Log Truck (A62679)
1996 International...
John Deere 148 Loader with Brackets (A65640)
John Deere 148...
12T Shop Press (A66408)
12T Shop Press...
2012 FORD E-350 CUTAWAY SERVICE BODY TRUCK (A59914)
2012 FORD E-350...
