CK30 has it's limits.
/ CK30 has it's limits. #1
IXLR8
Elite Member
Eastern Shore- Virginia
Kioti DK-40SE
The original owners of our home had one of those large 6ft satellite dish's. A subsequent owner turned the mounting post into a swing set. SWMBO decided that she wanted the 'swing' moved out of the side yard and into her garden. No problem... I though... just dig up the base, dig a hole in the garden, plant base... instant swing. :) When I got done digging around the base... I found it was 2.5ft in diameter and 4ft deep!!! I tried to lift it out... I could not budge it! :( Quick calculations show it weighs about 2700lbs!! :eek: No wonder I can't move it. I just cut the pole off, made a bigger hole and buried it.
Looks like I am going to be building a wooden swing now.
/ CK30 has it's limits. #2
A man's got to know his (and his machines) limitations.
They certainly didn't want that thing to blow down in the wind:)
Good job.
Tom
/ CK30 has it's limits. #3
I am still trying to figure out how they made a swing out of a single 6' pole. Sounds painful! :eek:
There was another pole bolted to the top of that one with a cross bar added across the top. This made it 'T' shaped, then the swings hung from the cross bar.
/ CK30 has it's limits. #5
... I could not budge it! :( Quick calculations show it weighs about 2700lbs!! :eek: No wonder I can't move it. .
Are you trying to talk yourself into a DK40se with 2700lb lift capacity to full height so you can lift that thing and dump it over your fence into the neighbor's yard?:rolleyes:
That is the first thing I thought of after I crunched the weight numbers. All you have done with your DK40. Neighbor has a big enough tractor so he could pick it up and give it back to me. I would have had him move it... but I just didn't want to deal with something that big... and if SWMBO ever wanted to move it again.. I didn't want to have to depend on him to move it. So I burried it and ordered some lumber to build a swing. I think a wood swing will look better anyway.
/ CK30 has it's limits. #8
LOL. I too had a 6' satelite dish in my yard when I bought my house. Before I had my tractor, I wrapped a strap around the top of the pole and thought I would pull it out with my pickup. It just bent the pole until it touched the ground. The first day I had my backhoe, I went after the pole. After digging for an hour, I had exposed a 55 gallon drum filled with concrete with about a foot more concrete poured over the top. After messing with it for a while, I came to the conclusion to dig a bigger hole and bury it was my best (only) option.
/ CK30 has it's limits. #9
I have a DK40se and am sorry I didn't get the DK55, but then if I had the 55 I'd want the 65 or 90.
Actually, I'm happy with the DK40 with my only complaint is that I can't really pull a 3 bottom plow.
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
2004 STRICK 53X102 T/A DRY VAN TRAILER (A59914)
2004 STRICK 53X102...
2012 WESTERN STAR  4900 SF (INOPERABLE) (A65643)
2012 WESTERN STAR...
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
2020 Caterpillar 302.7D (A64126)
2020 Caterpillar...
SDlanch SDLL580 (A64127)
SDlanch SDLL580...
