CK30 hard to shuttle/shift
/ CK30 hard to shuttle/shift #1
Kiotikarl
Quebec Canada
2010 Kioti ck30 gear
Hi everybody,
I have a 2010 CK30 with 200hrs, for sometime i have been experiencing hard shuttle shifting. I push the lever in either direction and it doesn't engage completely and when i realese the clutch you can hear the gears grind:( Same thing randomly happens when i put the tractor in first gear. The clutch is properly adjusted, is there anything i sould lube, or i got a bigger problem.
Thanks
Karl
/ CK30 hard to shuttle/shift #2
I also have a CK30 shuttle shift with about 150 hours. So far no problem. A few threads on here address a similar condition. Check the linkage, there is a fork that could be out of place a little or loose. I am not at home now so I cannot provide a picture or more detail.
/ CK30 hard to shuttle/shift #3
This might not be your problem at all, but it is simple to check and iif nessary, fix. And it was the cause of my Ck25's 'notchy' shuttle shifting.
There is a little roll pin in the shuttle shift linkage that can work loose or out. It's under the tractor where it attaches to the shaft that goes into the transmission. If it backs out, the slop/misalignment can cause it to not fully engage in eitther direction.
Since I found it the first time I've checked it frequently and tapped it back into place several times. Good luck. Hope for simple! -WSJ
Well, update on my own post. Tractor is 571hrs as of now, been to the dealer once and a few times used the at home service, and the problem has only worstened. At such a point that you have to stop the tractor to shift/shuttle, and PTO engagement is even worst.
Could the clutch be faulty, since this has been going on since day one/ brand new:confused:
Anyone ever had any problems with their clutch....?
/ CK30 hard to shuttle/shift #5
This very well could be a clutch that is out of adjustment. Make sure there is a about 1 to 1-1/2" of free play on the clutch pedal. BTW it is a good idea to come to a stop when shifting the shuttle. Hope this helps.
Since new the tractor has been doing this, dealer has ajusted the clutch many times, but that doesn't appear to do much. From a stop, if clutch is in all the way to the floor, when i shift into foward or reverse, you hear a loud grind and the tractor moves about an inch but not after its been engaged.With the clutch applied, once its in forward or reverse, i keep my foot on the clutch put the tractor back in neutral or in opposite direction, then back the other way and it does not grind. But if i release the clutch then want to shuttle again , the gears grinding. First gear a time wont go in or jumps out. This has been going on since day one, and only worstens.
/ CK30 hard to shuttle/shift #7
Sounds like a clutch problem. Best to fix it before it damages something else (and even more expen$ive).
I also tend to think it's the clutch, only thing that really pisses me off, is that it's been like this since brand new, and i'm going to have to pay for this. I sent kioti an email about this ..will see what they have to say.
/ CK30 hard to shuttle/shift #9
Sounds like clutch to me. I've never had a problem. Does the gear synchro work when changing gears on the move ?
Sent from my iPhone using TractorByNet
Gear shifting on the go is ok. But if the tractor is in neutral and i shift into first gear either it doesn't want to go in ( no grinding juste not going in ) or it will jump out when the clutch is released. So in order to be able to use first gear, i shift in a higher gear from neutral then back to first gear and its ok....:confused2:
Well guest i should update my own thread now. No news what so ever from kioti, not even a sorry but there nothing we can do. Just plain nothing. Guest customers aren't that important for them. Having had a few tractors, and of which 3 kioti (DK45SEC, CK30 and CK20S HST) i guess im not worth a response.
Dealer said clutch kit is around 1600$ but i can save by doing it myself.
I was a die hard Kioti fan, but guess now i'll have a CK30 for sale :thumbdown:, and going back to some other tractor color.
/ CK30 hard to shuttle/shift #12
I'd go after them as this issue sounds like it's been there since new as the dealer has adjusted it for this problem in the past and not really ever solve the problem, just helped a little bit or for a very short time.
Steve
/ CK30 hard to shuttle/shift #13
I don't have a Kioti, but customer service *should* be the same in this regard. First, document all your service incidents for the problem. If you don't have the paperwork, then at least approximate the dates for each service. Present this list to the dealer and demand that the problem be taken care of under warranty - your share should be $0. If the dealer doesn't respond in a positive manner, then go higher up. What you want to be is the wheel with a loud and persistent SQUEAK! Make sure they know you will not drop the bone even if you have to contact state officials, TV news stations, attorney generals - - you get the picture. They should not be allowed to get away with this!
bumper
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2019 K&K Equipment Trailer, VIN # 1K9PE2029KA175459 (A65563)
2019 K&K Equipment...
Location Info Please
THIS WILL BE A TIMED ONLINE AUCTION! (A65640)
THIS WILL BE A...
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
(1) 20 Yard Roll Off Dumpster and (1) 40 Yard Roll Off Dumpster (A65579)
(1) 20 Yard Roll...
