Loader Ck27 loader capacity. Lifting a giant pumpkin.
   / Ck27 loader capacity. Lifting a giant pumpkin. #1
pickeringchris
I went to weigh one of my giant pumpkins. Curled bucket back as far as it could go. Hooked crane scale up and proceeded to lift pumpkin. Scale went to 900lbs and I had no lift past that. Pumpkin was likely around 1000lbs.
I thought my loader capacity was 1150? Wtf?
Chris
   / Ck27 loader capacity. Lifting a giant pumpkin. #2
Now you know that 1150lb rating at the pins = 900lbs at where ever you were hooked:thumbsup: Bucket edge??? Bucket center???? Where exactally where you hooked at?
I have a hook welded to the top center of the bucket. The bucket was curled back all the way towards the tractor bringing the load point as close to the tractor as possible.
   / Ck27 loader capacity. Lifting a giant pumpkin. #4
I am having a hard time getting a visual. It isnt where you attach to the loader at. rather it is where the load is in relation to the loader.
If I am visioning it correctly, you had a rope/cable/chain or whatever attached at the hook, then running forward down over the cutting edge and dangling below to attach to the pumpkin. If thats the case, then the load is still centered at the cutting edge.
The only way you could have hooked to be RIGHT over the hook would have been to raise the loader, drive the loader up OVER the pumpkin, and let the rope/chain dangle BEHIND the bucket. BUT....your hook is probabally welded on the wrong direction for that.
   / Ck27 loader capacity. Lifting a giant pumpkin. #5
Crappy drawing, but if this is how you were hooked, thats would still be considered "cutting edge"
You are exactly correct about the chain position. No way I could do it the way your suggest because the pumpkin is too large in circumference. It was around 180" circumference. No big deal. It was rotting and I wanted to weigh it. Instead I chopped it up with the bucket and put it in the compost. Still, I was surprised the loaded couldn't lift more. I thought the 1150 rating was at the bucket. There is something else in the specs that says 1900 lbs break out at pins. I thought that was the capacity at the pins.
Oh well. :-(
Here is a pic before I chopped it up.
   / Ck27 loader capacity. Lifting a giant pumpkin. #8
LD1...
I'm tempted... :)
   / Ck27 loader capacity. Lifting a giant pumpkin. #9
Oh well. :-(
From a demo I've seen, by daves tractor, to do that u would lift to full lift capacity. Then, while at full lift capacity, u would curl for breakout force. Your scale should have gone all the way to full breakout force...at least, it did for daves tractor video on you tube. Search YouTube for max 25 lifts forklift...to see the video.
   / Ck27 loader capacity. Lifting a giant pumpkin. #10
LD1...
I'm tempted... :)
Tempted to what??:D
Yep you are correct.
The breakout force is basically the curl force. If I understand secs correctly, curling would have allowed you to lift 1900# at the PINS. So with the de-rating of moving out the edge....You would have probabally lifted the pumpkin.
To get that breakout, you basically have to uncurl the bucket so the cutting edge is close to level. Then RAISE until it wont raise any more (applying 900# of force in your case). With that force applied, you then curl. Thats breakout.
There have been lengthy discussions about the ratings of loaders. And trust me, its not just kioti. But it seems we are shifting away from usefull measurments and onto useless "at the pins" measurments. The reason is the numbers are higher back their, and higher numbers sell more tractors:confused2:
   / Ck27 loader capacity. Lifting a giant pumpkin. #11
unless you have a mahindra tractor:laughing::cool2:cut it in two and weigh seperate.
Fredw
   / Ck27 loader capacity. Lifting a giant pumpkin. #12
Fredw
Well... I resisted the temptation.:cool:
I see jumped in with both feet! :eek::shocked::D
   / Ck27 loader capacity. Lifting a giant pumpkin. #13
Chris if you had removed your bucket, and put on a SSQA plate with the hook on it it would have likely lifted it also. But as you pointed out due to the the diameter of the pumpkin you could not do that either. You know my tractor a DK35se would have likely lifted the pumpkin, but where do you draw the line? The tractor I have now will lift more than the one I traded in, but I still have hooked onto things I cannot lift, so do I trade it for a bigger one? There is always a bigger tractor, and always a bigger thing you could try to lift.. I think the 900 lbs out on the bucket edge was pretty good for your tractors size.
James K0UA
   / Ck27 loader capacity. Lifting a giant pumpkin. #14
James K0UA
Excellent point:thumbsup:
I have latched onto things with my 5500TLB (18,000lb machine) that I have not been able to lift. But I certainly am not going to go buy a bigger backhoe..................just yet:laughing:
   / Ck27 loader capacity. Lifting a giant pumpkin. #15
Maybe to squeeze some more lift, try lifting as high as you can with the bucket at full dump, then curl it to full up?
Nice sized pumpkin though! One of the guys at work is into pumpkins as well, and got a solid 700lb one last year, I'll have to ask how he did this year with all the heat.
Hey guys. Thanks so much for contributing to this thread.
When I got this tractor I knew I would be growing pumpkins beyond its capacity. I didn't get the tractor to lift em. I have a tripod for that. I just thought id give it a try. :)
Btw, I saw that YouTube video. Pretty cool. Was it me or was his front tire squashed right into the ground???
C
   / Ck27 loader capacity. Lifting a giant pumpkin. #17
C
I think u saw a squished tire... he put that little tractor to the TEST... to the MAX, even. :cool:
Note: It PASSED with flying colors :D
   / Ck27 loader capacity. Lifting a giant pumpkin. #18
I always assumed the lift capacity was without the bucket. If you figure in the weight of the bucket, you're pretty close. I am surprised it didn't lift it, even with the bucket on and in front of the pins since the rating is to full height. The higher the load, the less capacity from the loader. I tested it once with a large rock in the bucket on a very flat stable surface. I got about 4ft and couldn't lift any higher.
Adams Tender Trailer (A61306)
Adams Tender...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
2012 International 4300 Reefer Truck (A61306)
2012 International...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2016 FORD F-350 XL SUPER DUTY EXT CAB TRUCK (A59823)
2016 FORD F-350 XL...
