CK2620 to CK4020 or more
   / CK2620 to CK4020 or more
Also, sorry for the multiple short posts but, noone on YouTube mentioned anything about advancing timing.
Not only did Kioti back the fuel down they also backed the injection timing down to make the CK2610 and 2620 24.5hp. Very anemic. The injection timing and fuel screw really makes this thing run like its 100.5ci. I can describe the injection timing procedure if you would like. I advanced mine 4 deg.
   / CK2620 to CK4020 or more #22
Let’s see your dyno numbers before we all get “screwing” around with our tractors 🥴
Give me a couple weeks fellas. Ill get r done. Have any of you ever seen a tractor pto dyno before? Its nothing like a car dyno. It attaches to the pto shaft and turns a oil pump on the dyno. Ya bring up and maintain 540 pto rpm, restrict the output of the dyno oil pump until the tractor is at WOT and can no longer maintain 540 rpm. then the output pressure of the dyno oil pump is converted to HP. Then you can take the pto hp add 4 to 5 hp (for parasitic drag) to get engine hp. Look up tractor pto dyno on youtube.
   / CK2620 to CK4020 or more #24
Only seen on YouTube. I wonder how accurate/consistent true numbers are across machines? I get the impression that old shops from 60s/70s/80s had these, and it was common; and also the impression that the few shops that still do, have machines from 60s/70s/80s.
I would imagine the vast majority of them old dynos have never been calibrated. The bad thing is short of pulling the engine and mounting to a engine dyno a pto dyno is the only way we have to test our machines.
   / CK2620 to CK4020 or more #26
Out of curiosity, did it quiet down any after your tweaking?
Not that I really need more power in the 2620 I recently bought. It puts the BX25D to shame just by being heavier, its primary task being backhoe usage.
Have only used the Kioti twice so far (still under 5 hrs) and some say it could quiet down a bit by itself over time.
   / CK2620 to CK4020 or more #27
Engine? or hydro whining? Every says the hydro quites down after fluid change, but I never noticed either being loud. My hearing isn't great anyways.
   / CK2620 to CK4020 or more #28
No, the engine. It sounds much like an overly advanced diesel, with some "pinging" if you will.
   / CK2620 to CK4020 or more #29
Add cetane boost. Diesel in North America is barely above 40. 50-55 is ideal…
My 2014 CK30HST is relatively quiet running AMSOIL injector clean&cetane boost.
I’ve Been using it for about 6 years and noticed the difference right away.
I didn't realize it till you ask but it did and it cranks easier. The only time it smokes is under a heavy load or I advance the throttle quickly.
2005 Sterling Acterra Tender Truck (A56435)
2005 Sterling...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
PALLET OF TILE (A58374)
PALLET OF TILE...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
2007 International 4300 Altec DM47R Insulated Digger Derrick Truck (A55973)
2007 International...
