CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't.
   / CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't. #1
MF 35
I'm just checking if I am missing one, or if I should just order it (for $19, might as well just order it). However, I am curious.
Thanks!
   / CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't. #2
nope. i have a filter on my fuel storage tank and pump.
   / CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't. #3
Nope…but my funnel does
   / CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't. #5
You do realize that no vehicle ( car, truck, etc) uses a screen? I had one in my 55 gal fuel storage tank and i removed it because is slowed down refueling the diesel by at least 50% … probably more. When the level gets to the bottom of the screen, it always backed up and overflowed or shut off the pump. It sucked.
   / CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't. #6
I second that. I bought a water separator funnel, it keeps water out as well as dirt, but what a very slow process, while hoisting a 5 gallon container.
Better than having water in tank, but now it collects dust.
   / CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't. #7
Yup, i had one of those long ago. No idea where i tossed it. I use this now. Filters everything
   / CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't. #8
2018 Boomer 40 made by LS has a drop in screen in filler neck. Works great for me. Montana 5740 had one also. Both remove for cleaning if needed.
   / CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't. #9
Kubota sells a one size fits all strainer for about 10 bucks. Have them in both my tractors plus a Racor Fuel polishing filter.
   / CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't. #10
My funnel has a screen….I can blow dirt off anytime if it needs to be 😉
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
Polaris Sportsman 500 (A51573)
Polaris Sportsman...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
2019 RAM CUTAWAY SERVICE BODY TRUCK (A52577)
2019 RAM CUTAWAY...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
