CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't.
   / CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't. #1
MF 35
I'm just checking if I am missing one, or if I should just order it (for $19, might as well just order it). However, I am curious.
Thanks!
   / CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't. #2
nope. i have a filter on my fuel storage tank and pump.
   / CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't. #3
Nope…but my funnel does
   / CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't. #5
You do realize that no vehicle ( car, truck, etc) uses a screen? I had one in my 55 gal fuel storage tank and i removed it because is slowed down refueling the diesel by at least 50% … probably more. When the level gets to the bottom of the screen, it always backed up and overflowed or shut off the pump. It sucked.
   / CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't. #6
I second that. I bought a water separator funnel, it keeps water out as well as dirt, but what a very slow process, while hoisting a 5 gallon container.
Better than having water in tank, but now it collects dust.
   / CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't. #7
Yup, i had one of those long ago. No idea where i tossed it. I use this now. Filters everything
   / CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't. #8
2018 Boomer 40 made by LS has a drop in screen in filler neck. Works great for me. Montana 5740 had one also. Both remove for cleaning if needed.
   / CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't. #9
Kubota sells a one size fits all strainer for about 10 bucks. Have them in both my tractors plus a Racor Fuel polishing filter.
   / CK2620 - Did your tractor come with an in-tank fuel strainer? Mine didn't. #10
My funnel has a screen….I can blow dirt off anytime if it needs to be 😉
2006 Ford Explorer 4x4 (MPV), VIN # 1FMEU73E36UA28575 (A51572)
2006 Ford Explorer...
2008 UTILITY DRY VAN TRAILER (A52576)
2008 UTILITY DRY...
2019 FREIGHTLINER CASCADIA (A52577)
2019 FREIGHTLINER...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2014 INTERNATIONAL LF687 SLEEPER (A52576)
2014 INTERNATIONAL...
2015 Linde H35D 4,350lbs. Diesel Forklift (A51691)
2015 Linde H35D...
