CK20HST/CT122 with chipper?
   / CK20HST/CT122 with chipper? #1
Paystar
Elite Member
Ontario, Canada
Kubota B2620
Just curious......the CK20/Bobcat CT122's are listed at 16.5 pto h.p. This is less than most scuts at 19.5. Is it just the way Kioti/Bobcat rate them? Will a CK20/CT122 run a wood chipper? What size chipper is anyone running?
   / CK20HST/CT122 with chipper? #2
I have a Bearcat CH5540H 5" Chipper that I primarily use on my DK50. I have run it on the CK27HST which is below the the minimum stated 25 HP at the PTO by 4.5 HP. I was expecting it to not work but it did very well.
You have to feed more slowly but I think the big flywheel in the chipper really offsets the lower HP. I wouldn't recommend running that chipper on the CK20 but a smaller model should work fine if you are close to the recommended HP spec and are reasonable in what you feed into it.
   / CK20HST/CT122 with chipper? #4
I have a 4" MacKissic on my CK20 works well.
   / CK20HST/CT122 with chipper? #5
FWIW, Dr. Co. makes chippers too, may be better suited to your HP range on your tractor.
Here's a link:DR Power Equipment - PTO / 3 Point Hitch Wood Chipper Models & pricing - manual and elec start chippers
They often have 'trial' periods of up to 1 year so you can try before you own it. Full disclosure: I did get one of their PTO units on the trial program but never actually used it. I decided my $ would go to some other piece of tractor equipment, and returned it to their factory store in VT. I do have other pieces of Dr. equipment and they are adequate for light to medium duty use.
If you plan to chip a forest into mulch then go with something sturdier; but then you're up against HP/output again.
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2020 KENWORTH T680...
2008 JCB 190 ROBOT SKID STEER (A60429)
2008 JCB 190 ROBOT...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2023 MORBARK WOOD HOG 6400XT HORIZONTAL GRINDER (A60429)
2023 MORBARK WOOD...
2014 F-150 STX (A56438)
2014 F-150 STX...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56438)
Michelin CARGOXBIB...
