CK20 Rear working lights...
/ CK20 Rear working lights... #21
as I recall, just a cutting wheel and a razor knife to cut and trim the corners...
/ CK20 Rear working lights... #22
Gerard and mathey, please fill us in on how you did the electrical connections. Love the switches you did mathey, they really "belong," but where are your lights? Did you mount them in the same way that Gerard did? I have eyed that location many times and have planned to do the same thing, but haven't gotten around to it. Thanks for the posts. John
/ CK20 Rear working lights... #23
My lights (2 forward, 1 rear) are mounted using u-bolt around the ROPS, attached to a piece of square aluminum tube, just slightly below and slightly behind the ROPS. I'm not really happy with this setup, as it tends to light up the "cockpit" way too much...i'd prefer if they were higher, and more forward, but I can't see any options in this...they really need to be protected from branches and such...
the wiring (not finished in the photos) is tucked into a plastic sleeve and cable tied to the ROPs. I have them hardwired to the battery (fused)...there's a work light hookup hanging near the fuel tank, but i chose not to use that...
/ CK20 Rear working lights... #24
Nice installations. I setup (2) 55w driving lights on my L3410 using some angle brackets that I believe came with SMV emblems or gate hardware. I keep a lot of misc parts around and once in a blue moon I find a use for them!
Anyway, I ran 6 gauge wire from the battery (in front of radiator) to a fuse panel in the rear for all 12v stuff. There is a light circuit, hydraulic filter pump, and 12v rear connector for spraying and running an inverter (lighted hay wagon for Halloween). Check out the pictures...
/ CK20 Rear working lights... #25
Photo (2), Mounting brackets
/ CK20 Rear working lights... #26
Photo (3) Switches
I utilized the stock (+/-) wires behind the SMV/fuel tank for my wiring. The way I installed the work lights and the beakon light, I can within 5 minutes, return the tractor to stock condition. /forums/images/graemlins/cool.gif
Here is the lighter plug location for the beacon light. Notice the <font color="red"> </font> color of the work light bar now.
And finally, here is the loose (quick detach) restraint for the coil cord. /forums/images/graemlins/cool.gif
/ CK20 Rear working lights... #30
</font><font color="blue" class="small">( Notice the color of the work light bar now. )</font>
OOO AHHH. Thanks for the pics. That should be a pretty easy setup. Maybe I'll get to it this week. Which paint did you use? Looks like a great match from the pic. John
Actually that is reflective tape. Quick and easy and it looks great! /forums/images/graemlins/smile.gif
Plus it gives added safety.
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
4' Mower Blade (A62679)
4' Mower Blade...
2015 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2015 Kenworth T800...
2006 W-W TRAILER 20' T/A ENCLOSED TRAILER (A65643)
2006 W-W TRAILER...
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A64553)
2025 GIYI GY-P45...
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
