CK20 BH frame flexing
/ CK20 BH frame flexing #1
chelydra
Ditch Witch
While we're on the general subject of structures twisting under load... I occasionally use the BH on un-level ground, say 5 degrees slant. (Never much more so far; just doesn't feel safe.) I set the outriggers to level the BH, more or less. The frame flexes so much that all four tractor wheels stay on the ground at apparently equal pressure.
Is this acceptable, or do I need to level an area large enough for the whole tractor and BH before working? That would make a real mess of the landscape.
Thanks-
Chelydra
/ CK20 BH frame flexing #2
I haven't tried to lift the back wheels off the ground but my outriggers can certainly lift the rear tractor weight sufficiently to see the rear wheels become "unsprung" with no problem. Mine is the KB2365 on the CK20 and I have loaded rear tires.
Sorry - didn't mean that outriggers can't lift the tractor body. Instead, if I level the BH on a slope, the BH-tractor link seems to be able to twist several degrees.
/ CK20 BH frame flexing #4
</font><font color="blue" class="small">( the BH-tractor link seems to be able to twist several degrees.)</font>
I think you mean to say the subframe, and yes, it will, by its construction, flex a good deal, but you can also bend it that way.
If you're doing just a bit of slope, it shouldn't be a problem, but I think you can see the potential for damage if you have a lot of slope.
When you are on a slope, don't try picking up the down side to where the tire comes off the ground and you become level. Not only are you taking away part of the support from the rear tire, you're also putting too much stress on the stabilizer. They're not built to withstand much of the stress of being the total support.
If you were on a slope, lifted the rear tire off the ground to get level and the stabilizer were to break, the momentum could be enough to flip the tractor over on you. Better for you to sit a little crooked on the slope with the stabilizers just engaging the ground enough to keep the rear end from being pulled down with your digging strokes, that's what they're designed to do on a compact tractor.
I have recenlty been reading all that I can find about different ways of using backhoes, and cutting out level areas is a theme that keeps repeating in the different media I've found.
Yes, that could be detrimental to landscapes, but if it's a steep slope, you shouldn't be depending on a compact tractor backhoe's stabilizer to hold you up straight on it.
I've used mine many times with the tractor and backhoe at an angle, and it feels strange, yes, but I don't have a problem using it while I lean to one side. I think it goes with my lopsided brain just fine! /forums/images/graemlins/grin.gif
John
/ CK20 BH frame flexing #5
When I use my backhoe, I usually lift the back wheels off the ground an inch or so. The reason being that usually after the first scoop or two their on the ground anyway as the outriggers have sunk into the ground. I would rather have an outrigger break off than put undo strain on the back axle of the tractor. Some of the functions of the backhoe on mine anyway can put a ton of force on the back axle on top of the weight of the tractor. I've lifted the front end of the tractor unknowingly on soft ground in the woods digging stumps out. The ground is soft enough that the outriggers sunk out of sight and the tractor hinged on the back axles. Call it missuse or whatever, it was done unintentionally, once I realized what happened, I would lift the backend up some more or move to get on more solid ground. I never intend to missuse my tractor but sometimes it happens.
Steve
/ CK20 BH frame flexing #6
</font><font color="blue" class="small">( When I use my backhoe, I usually lift the back wheels off the ground an inch or so. )</font>
Of course, you may use your tractor any way you wish, but Kioti states in their manuals to leave the rear wheels on the ground for extra support. The backhoe stabilizers are not heavy-duty enough to support all of the tractor's weight and the stresses of the digging.
You're not really putting that much stress on the axle if you have the stabilizers down firmly without lifting the tractor, and you'll be protecting the stabilizers from undue stress. The stress to the axle is spread out evenly across it if you don't have it lifted.
John
/ CK20 BH frame flexing #7
I would echo KiotiJohn's point but also add that having the rear wheels on the ground (or the FEL dug in solidly) is a good idea to prevent twisting the stabilizers when you curl the bucket and "drag" the tractor backwards. That sort of stress on the stabilizers would not be good. They are really designed to prevent the tractor from tipping sideways and I doubt they are engineered to act as anchors as well.
I'm finding this discussion as useful as usual for this group - combining guidance and moral support.
I drive the BH pretty hard (though never above 2000 RPM - that's already a lot of power!), and generally press down the stabilizers about enough to raise the wheels by half an inch an inch or so. So the tires aren't anywhere near off the ground, just unloaded by a few hundred pounds. This lets me use the parking brake to hold against dragging, while making the whole thing more stable. I've never actually lifted the rear wheels; seems unnecessary and risky for the machine.
Now if I could just figure out why the loader creaks so much since the dealer's first 50-hour service. he says it's OK, so I hope that if anything breaks, it happens w/in warranty.
On a slightly related topic, what do people do for grease guns? I had to bend the end of mine to reach the lower BH swing pivot zerk. Seems like there ought to be a more elegant solution.
Thanks as always-
Chelydra
(Attached pic is a 200-lb yew getting a ride to a new location. Bit tippy unless I load a log or some dirt up front, but minimizes handling so best for rootlets.)
/ CK20 BH frame flexing #9
I use a flexible hose end on my grease gun. Fits into most places. But a shorter "head" would be useful for tight right angle applications. Also, the single hand trigger gun is more convenient when you have to use one hand to hold the head tight to the zerk.
/ CK20 BH frame flexing #10
Chelydra, do yourself a favor and order this air grease gun from Harbor Freight: Grease Gun Fun
It comes with a metal fixed and a flexible hose. I bought one two years ago for my CK20HST, and it's a great gun. Only $11.99 still.
If you don't have a compressor, Harbor Freight has them on sale all the time. You don't need a really big one, just get an 8 gallon or so, usually less than $100 at HF.
For an inexpensive gun, this one is surprisingly good. I rarely ever have to pump out air pockets, but it's easy to accomplish if you need to with this gun.
John
/ CK20 BH frame flexing #11
Why go to all the trouble. Just get a rechargable one less expensive in the long run and does the same job
/ CK20 BH frame flexing #12
</font><font color="blue" class="small">( Why go to all the trouble. Just get a rechargable one less expensive in the long run and does the same job)</font>
It's not a lot of trouble to hook the gun to the compressor.
I use the compressor to run my impact wrench, the grease gun, and a blower to clean off the hydro disconnects as well as cleaning the radiator and prescreen etc.
If I were worried about "all the trouble" I sure wouldn't have bought a tractor! /forums/images/graemlins/grin.gif
John
/ CK20 BH frame flexing #13
</font><font color="blue" class="small">( I'm finding this discussion as useful as usual for this group - combining guidance and moral support.
Thanks as always-
Chelydra
(Attached pic is a 200-lb yew getting a ride to a new location. Bit tippy unless I load a log or some dirt up front, but minimizes handling so best for rootlets.) )</font>
I did just what you did in that picture with the other K brand machine and bent the curl cylinder, I didn't notice it till I went to dig up another stump much smaller.
I feel the weight of the stump hanging on the bucket overstressed the cylinder in full extension.
I have not done that since and a few hundred stumps later it is still straight.
/ CK20 BH frame flexing #14
I know I have all that stuff too, I was only thinking of convenience, if you are bush hogging or something and just need a couple quick shots of grease, with the rechargable you just hit the fittings and you are done and don't have to wait for your compressor to air up and drag out airlines etc.
/ CK20 BH frame flexing #15
</font><font color="blue" class="small">( I know I have all that stuff too, I was only thinking of convenience, if you are bush hogging or something and just need a couple quick shots of grease, with the rechargable you just hit the fittings and you are done and don't have to wait for your compressor to air up and drag out airlines etc.
)</font>
I see what you mean, but I couldn't pick up on it because I always grease everything on the loader, backhoe and mower with every 4-5 hours of use. I can't see a time that "I" would need to give something a quick shot, but it makes sense for anyone who doesn't grease as much as I do.
I know a lot of people don't do it nearly as often as I.
You're right, it takes a little to set up, but I do all of it the same session, and then don't worry until the next 4-5 hours of use.
One like you mention would come in handy in the field, on a job. I've never used one of that type. Might be something good to get since I've been doing more jobs that last longer than my normal greasing schedule.
Good food for thought, thanks.
John
2020 KENWORTH T60 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 KENWORTH T60...
Stout Brush Grapple HD72-4 (A66285)
Stout Brush...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
121A (A63745)
121A (A63745)
Paladin 12in Digging Tooth Bucket Excavator Attachment (A64194)
Paladin 12in...
