ck20 backhoe controls??
/ ck20 backhoe controls?? #1
natem
Stonington CT
Kubota L-45
Just wondering how the backhoe control levers are set up. I am used to useing the john deere controls just did not know if they were the same. Also I see that they have a curved boom backhoe for the ck20, just wanted to know if anyone knew the benefit verses the straight. One more thing, is there a difference between the 2007 and the 2008 backhoes?? Thanks for the help
/ ck20 backhoe controls?? #2
The backhoe controls are "CAT" controls so they are different from "Deere" controls. I am sure the dealers on here can tell you if there are any changes for 2008 model BH's. I heard the curved booms are stronger, lighter and easier to see your bucket but I don't have any experience with one. Mine is straight and has amazing power for it's size.
/ ck20 backhoe controls?? #3
A curved boom offers better reach and visibility.
As for the difference between the 2365 vs 2465, it's the following.
MODEL KB2365
Digging Depth 76.4"
Reach (From center of Swing Pivot) 105.5"
Loading Height (Bucket at 60¡Æ) 63.6"
Swing Arc 180¡Æ
Transport Height (Maximum) 73.1"
Transport Overhang 43.5"
Bucket Rotation 180¡Æ
Stablilizer Spread (Down Position) 76.8"
Stabilizer Spread (Up Position) 49.2"
Shipping Weight (Less Bucket) 785 lb
Bucket Digging Force 2,875 lb
Dipperstick Digging Force 1,744 lb
Operating Pressure 2,000 psi
MODEL KB2465
Digging Depth 76.3"
Reach (From center of Swing Pivot) 113.1"
Swing Arc 180¡Æ
Transport Height (Maximum) 77.2"
Stablilizer Spread (Down Position) 68.7"
Stabilizer Spread (Up Position) 46.4"
Shipping Weight (Less Bucket) 1,036 lbs
Bucket Digging Force 2,817.5 lbs
Dipperstick Digging Force 1,748 lbs
Operating Pressure 2,466 psi
OK, that is what I feared. I wonder if I could just switch the hoses on the valves so they would match the Deere controls, i don't know if this is possible does anybody??
/ ck20 backhoe controls?? #5
Correct me if I'm wrong........
It depends on if you are talking about a JD commercial Hoe or a JD TLB.
I have used a JD TLB and the Controls are the same as the Kioti.
Unless someone had changed them.
BTI
/ ck20 backhoe controls?? #6
I could be wrong but I think there are backhoe controls and excavator controls which are different, but some small excavators have backhoe controls. Confused, I am.
Steve
/ ck20 backhoe controls?? #7
You and me Both LOL
I've run alot of TLB's but never a real live backhoe or excavator.
BTI
I was referring to a 410G which is a commercial backhoe, and it does have a switch in it for back hoe controls or the excavator controls. I will go to the dealer and try one out first hand and see what the controls are.
One more question, how do I know if a loader for a 2008 ck20s is an actual 2008. I know there were issues with the 06 or the 07 cracking just not sure which year. Thanks for the help.
/ ck20 backhoe controls?? #9
I rented a Yanmar Vio27 and it had a lever that would switch between SAE and ISO controls (cat and deere) but the Kioti has nothing like that, I doubt any compact tractor does.
As far as the loader, the updated loader is the KL120B as opposed to the KL120. The updated loader also has a tube that cleary goes through both arms whereas the old design is a fulley enclosed box with an access panel on the bottom.
/ ck20 backhoe controls?? #10
Look at the serial number plate on the loader. The new version (non cracking) is the KL120B, the older version is the plain KL120. Also, there is an obvious physical difference you can see by looking at the torque tube from the side. The new version has a pipe that extends all the way through the torque tube while the older version does not.
I checked them out today and the BH controls are the same as the deere.
2007 JLG 450AJ TELESCOPIC BOOM LIFT (A65056)
2007 JLG 450AJ...
2011 WESTERN STAR 4900SA (A63569)
2011 WESTERN STAR...
PORTA POTTY (A68842)
Unused 2022 Land Pride QH30 3 Point Quick Hitch Tractor Attachment (A66734)
Unused 2022 Land...
2002 MACK RD688S ROLL OFF TRUCK (A67714)
2002 MACK RD688S...
2025 Swict 66in Bucket Skid Steer Attachment (A66734)
2025 Swict 66in...
