CK 27 HST
/ CK 27 HST #11
Thanks for the info, I’m looking at purchasing a CK3510HST (open station). I will be using it for plowing here in Fairbanks and the temperatures are a bit colder. I was wondering how a soft cab would work.
That soft cab is cool but. Do yourself a favor if at all possible and get the factory cab. Or at least a hard cab with heat. You will regret not getting it more than you will regret spending the extra $ if plowing is your main use.
/ CK 27 HST #12
In the long run I will probably just build a cab. Tractors cost way to much up here for me to be able to afford a cab model. Plus the dealer is already 350 miles away anyway.
Toro Sand Pro (A56859)
CFG Industrail MX15RX (A53317)
CFG Industrail...
Giyi Mini Ex Attachment Set (A60463)
Giyi Mini Ex...
(4) MJ Fittings (A60463)
(4) MJ Fittings...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
