NX series three-point lift cylinder rebuild? Are the caps welded on?
   / NX series three-point lift cylinder rebuild? Are the caps welded on?
I had a no start issue with my NX4510HST a few years back. It was the wiring harness where it plugs onto the ignition switch. It had just rattled itself loose a bit. I pushed it back on and it has been fine ever since. Hopefully your problem is just as simple.
Sadly, I've already looked at that switch and connection.
2012 PETERBILT 388 WINCH TRUCKS (A58214)
2012 PETERBILT 388...
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
Warrior CAT320 53in Bucket W/Pins & Replaceable Teeth (New/Unused) (A59225)
Warrior CAT320...
2014 Freightliner 122SD Day Cab Truck, VIN # 3AKJGNDR0EDFL0999 (A57453)
2014 Freightliner...
