citrix/centrix speaders?
/ citrix/centrix speaders? #1
psuedofarmer
new hampshire
Kioti DK55 Cab, 3 NHs (from 40-90HP)
not sure what the manufacturer name is, but has anyone purchased ag equipement from this maker?
i'm looking at a 300lb spreader but i wanted to learn more about the maker before buying (and i can't track down the name via the web)
thx
pf
/ citrix/centrix speaders? #2
Sitrex
I have a Sitrex spreader that has worked well for me for the past three years.
Kevin
thx kevin - that's the name i'm looking for.. i'm looking at the 300lb model. the manufacturer suggests that you can use it to spread sand/salt.. have you used this spreader for anything other than fertilizer?
thanks again!
pf
/ citrix/centrix speaders? #4
I only spread fertilizer with it. But I did order the optional agitator so I don't see why sand and salt wouldn't work.
Sitrex Website
Good Luck,
Kevin
/ citrix/centrix speaders? #5
they have a sitrex 300 and a 500 and I have the 500. that is the model number and will hold anywheres from 500 to 1000#s of fertilzer depending on what kind of fertilizer since some is heavier then others. The 500 model just has a bigger cone at the top and is only around $500 with the agitator. most farm places carry them around here. I have had mine for 3 years and works well for money. Wash it out real good the salts from fertilzer will rust it quickly. Sand may work if there is no rocks in it but dont fill it too high. i have spread calcium Chloride with it a on dirt road for dust. They are a good cheap spreader for someone who will only use it once or twice a year on small acreage. I have photo attached of mine holding 800lbs on tc33d.
Mike
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 GMC 1500 Sierra Crew Cab Pickup Truck (A61573)
2015 GMC 1500...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
