Cistern
/ Cistern #21
Darren:
Any chance you could post some pictures to help us (me anyway) visualize the situation?
/ Cistern #22
sure sounds like you've already done a lot of work, with a bunch more to go. sometimes its best to cut bait and start all over..any chance of putting this system closer to your house, so you could catch the roof runoff, and then put a pump in the cistern to get the pressure you are looking for in the location your using now..pumps are cheap and last a long time.
heehaw
/ Cistern
For whatever reason when the house was built sometime in the 1860's, it was placed on the point of a small plateau which is also the lowest elevation on the plateau. The kicker is that there's no space immediately near the house to sink a cistern. Within a short distance of the house the ground either drops off abruptly or rapidly goes uphill.
One of these day's I'll have to look into a digital camera. I have a few pictures of the cistern excavation that I might be able to get scanned.
/ Cistern #24
I think in the old days cisterns were plastered to prevent leakage. You also would most seriously want to look into lining it with bentonite clay first - some weird stuff, stops moisture. I would really, really look this up. Good to get it right, impossible to redo if it's wrong! Concrete silos were plastered too to make the air-tight. You need to talk to those types of people.With the steep slope you are on, you need to worry about water pressure (& frost, made worse by water pressure) on the concrete when it is empty. you could be in the middle of a spring, & that will cave in a side if the cistern is empty. I think you might want some gravel & drain around it. Again, something I would really look into - hillsides are known for this!You said it is 50' long, is your cement mixer on an end or the middle of a side? It wouldn't seem very hard to chute the concrete into the bottom if you are on the middle of a side, wouldn't take that long of a chute. You might need a lot more labor than you think, get some folks down there with wheelbarrows, shovels, & levelers... ;)I too would worry about cracks forming, since this doesn't seem like it will be a single pour. I have no solutions or ideas for this.I don't understand your point about just digging deeper to increase capacity, as you've said you hit rock, & once the concrete is poured, you will not be digging any deeper!Why did you need 100' of fall? My livestock is fed from a more conventional round cistern 60 years old. The bottom of the cistern is about 4-5 feet above the faucet level in the barn. With inch & a half pipe, I've got water for 40 head of cattle, could double that & not worry about flow rates.... I'll assume you just have a difficult location & this is all that works, but you sure could have gone with less head.I think you have studied this better than we think, & I'm not trying to talk down to you, I'm sure you've planned & consulted for much of this already. Just tossing out those whacky ideas.--->Paul
/ Cistern
I don't take anything someone says as talking down to me. There's a lot of experience on this board. If nothing else through the years I've learned that you can't plan enough and ask enough questions. Every suggestion and comment stokes the brain. I may come across a bit short at time but that's not the case.
Waterproofing is a major issue. Usually a surface treatment using something like Thoroseal does a good job. What I've been looking at is other ways of making concrete impervious. One that's used for bridge decks and parking structures is silica fume also called micro silica. The particle structure is so fine it's very effective at filling the microscopic voids in concrete that permit the passage of water. It's finer than cement.
I've talked to the block plant and got their agreement to incorporate silica fume in the block mix. The same additive can be used in the mortar, the grout for the cells and the slabs. It turns out I'm a few hours away from a major source which helps since it's not normally stocked by concrete suppliers and I'll need a couple of pallets of the stuff.
Since a cistern in use is constantly exposed to water, another concern is the use of anything that can cause spalling later. I've already bought a 4" stainless steel drain.
I also came across a surface treatment that utilizes a chemical reaction to seal block and concrete. It is approved for potable water use.
Among the things I have to do is layout the work area and see how everything will fit in. That's a major concern. The pit is only accessible from one end. There's some room on the uphill side but I'm not sure it's enough to park the mixer and provide access for loading.
I'm going to do a trial run on something that needs a couple of yards to look at cycle time. I may have to use an additive that retards setting time to eliminate cold joints just in case.
The reason for the height is that I want to be able to run the water system without a pressure tank and switch and still have at least 40 psi. I'm working with something over 100' of elevation difference. Because of access problems, fire insurance is more expensive. I don't expect the premium to go down, but having 40 or 50,000 gals of water feeding a high pressure pump might make a difference if there's a fire.
For backfill, I'll be using clean sand wrapped in geotextile to minimize active earth pressure along with a perimeter drain around the base. Like you said, I'll only get one chance to get this right. I'll have a local engineer design the structure. I'm not doing this by the seat of my pants.
I did find some pictures of the site that I'll post after I get them scanned.
/ Cistern #26
For ponds we use rubber roofing a 20 x50 rollis about 350$. Wouldn't even need a frame just dig a hole and line it. Charcoal filter on the outlet. You could also build out of wood easier and probably cheaper and line it with it.
/ Cistern #27
Don't know how close you are to Winston Salem, but there are 100+ epoxy lined steel tanks on the market there, from a soft drink plant, being offered for sale at 25 cents a gallon of capacity. Sizes range from 20 to 50 k gallons.
Phone number if you're interested is 717-426-4919
/ Cistern #28
Even grouted walls are going to leak. ( I'm a Civ-Eng.... I see it all the time...... Unless it is epoxy lined or something similar.. but better watch out for setteling.. will crack that concrete.. even if reinforced... )
Be thinking about a liner.. possible a pond liner. Most landscaping or pool places can get these.
Soundguy
/ Cistern
A certain amount of leakage wouldn't be a problem. From what I've seen walls properly coated with Thoroseal don't leak. The other sealant I have to check is one that's approved for potable water and involves a chemical reaction.
How familar are you with silica fume used to eliminate intergranular voids in concrete used for parking garages and bridge decks?
As for the concrete settling, I'm down to solid rock. As long as I pour a working slab first before the cistern slab, I don't see how settlement is an issue. Other than the possibility of an expansion/contraction crack, what else could happen? As long as I eliminate settling, how do I prevent cracks or use waterstop and a built in expansion joint to eliminate cracking?
FWIW, a large tank isn't doable. There's no way do get something that size and weight on site. The ex-soft drink tanks have been available out of Baltimore. The weight and size make them impractical.
/ Cistern #30
Thorough seal can leak....if the walls crack after thorough seal has already been applied.Been there done that,a round concrete cistern will hold water better than a square cistern,a square cistern can cause you problems in the corners..Ever consider using something like a silo stave ?
/ Cistern #31
I've worked with a few concrete mixes with various additives for strength and/or water barier properties.
As for settling, if the bottom is fixed.. ie rock, that eliminates that problem.. that just leaves the sides.
If it were me.. I would use a square tank with a liner.. though a round tank is going to have less stresspoints ( more cost ).
The liner will be slightly more forgiving than a waterproof coating.
Either is doable though.. people use it all the time.
in a related issue
We just worked up a spring box for one of our estimators who is building a home in georgia. Luckilly he had a spring on his side of the mountain, while his neighbor has drilled 2000 ft with no water. In the end the other guy just decided to tap off the spring box and help for costs etc.
Soundguy
/ Cistern #32
2000' /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif,what kind of pump would he have used to get water out at 2000' if he had hit water. /forums/images/graemlins/confused.gifDid he hit oil or gas that deep? I have a water well at 509'(hit water at 435'--- 74' pocket) and I thought that was deep.What did they charge for a 2000' dry hole?
/ Cistern #33
Let me guess: The same as a 2000' wet hole? /forums/images/graemlins/smirk.gif
Kevin
/ Cistern #34
When my well was drilled...the agreement was if he drilled a dry hole...no water /forums/images/graemlins/crazy.gif he would only charge 1/2 the price of drilling that he would normally if he hit water. /forums/images/graemlins/tongue.gif
/ Cistern #35
</font><font color="blue" class="small">( )</font> 2000' ,what kind of pump would he have used to get water out at 2000' if he had hit water. Did he hit oil or gas that deep? I have a water well at 509'(hit water at 435'--- 74' pocket) and I thought that was deep.What did they charge for a 2000' dry hole? </font><font color="blue" class="small">( )</font>
I'm not sure on the pump or pumps he was planning on using.. ( perhaps charge or assist pumps... not sure ) But I'm glad I live on flat ground.. I wasn't pleased when my 140' well fell in the same day of drilling, and had to go another 100'.. and that was at 9 bucks a foot.
The gentleman in georgia pad ( if I rember correctly) 7 bucks a foot.. but they only charged him something like 5600 bucks for the um.. core sample they took. /forums/images/graemlins/shocked.gif
He ended up using a springbox with a bluelight kit for disenfection.
soundguy
/ Cistern #36
I have been fortunate with my well,it was drilled in 1987($5.00 ft) and we have NEVER had a shortage of water,I have watered cattle/my garden etc...it was a rotary outfit that drilled it,the well driller said there was a vane of sand about 400' deep that the water was in...he got in the sand a 435' and the sand was about 30' thick and that was where the water was. We have a Gould 1 1/4 h.p. submersible pump.
/ Cistern #37
Wells are funny things... mine was originally around 140.. now 240.. but a guy oh.. about 10ac west of me has a 700' well... The guys drilling mine drilled his the year before and thought that they would never hit good water....
Glad I didn't pay his bill either....
Soundguy
/ Cistern #38
In 1975 when I was a teenager,the same guy who drilled my well drilled one about 3 miles away from me for a guy I knew and it was in a creek bottom,(I am on a ridge).It was after dark and they had lights up and was drilling on a summer evening and at about 60' they hit an artesian well,it was not a gusher the water just came to the surface and ran down through the hayfield,they did not use that well,they moved the rig about a 100 yards and drilled another well which they used. My understanding was the reason they did not use the artesian was it was difficult to set the pump etc.....?? At least that is what they said.And the water still comes out of the artesian and keeps a section in the hayfield wet today.
There have been a lot of dry holes drilled in this area and a lot of wells that were very marginal to say the least. I still see a lot of people hauling water tanks in there trucks,if you have a good water supply you are fortunate. I feel sorry for the ranchers/farmers who are suffering through a water shortage.
Ford 7000 (A64127)
Ford 7000 (A64127)
2021 PermaGreen Ride-On Speader-Sprayer (A64194)
2021 PermaGreen...
2017 Cat 316FL Excavator (A62679)
2017 Cat 316FL...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
EZ Trail 3400 (A63688)
