Tiller Choosing a tiller?
/ Choosing a tiller? #1
tom4018
South Central Ky
Kubota M7040HD
Looking at tillers to go on my tractor, Kubota M7040 (62 pto hp). Found a Landpride RTR1574 for $2200, Kingkutter's, Hawkline's and Tarters all around $1700 for 6 footers. Most of the literature I read show about a 50 hp max for this size. Will I be too risking too much damage to the tiller? Probably won't till but a acre or so a year.
/ Choosing a tiller? #2
What kind of ground do you have? I've had a 6' KK for 10+ years and wouldn't hesitate to hook it to a tractor with 62 hp pto hp. Make sure the slip clutch is adjusted and make multiple passes when you need to break new ground.
For a once a year deal, why not rent a tiller? My local equipment dealer rents attachments, gets ~$50/day for a tiller.
I will have to check on the rental to see if any one does that, although none would be very close. I would use it some for food plots in the fall too. Really don't know how to desribe the ground, some of it works pretty good and some is a clay type. Wanting to work in some organic matter to improve the soil.
/ Choosing a tiller? #4
If you keep your slip clutch adjusted correctly, you will be able to run on a 100 hp tractor tractor and not worry about the tiller. Ken Sweet
2015 KOMATSU PC240LC-11 EXCAVATOR (A62129)
2015 KOMATSU...
2022 John Deere HPX615E 4x4 Gas Utility Cart (A61567)
2022 John Deere...
more info coming soon! (A61569)
more info coming...
UNUSED REMOTE CONTROLLED DUMPER TRUCK (A62130)
UNUSED REMOTE...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
UNUSED WOLVERINE QC7-26-12.5G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
