Chinese diesel generator?
/ Chinese diesel generator? #21
Chances are there are a lot of RV's out there with LP Onan generators. :D
One site site that describes a slow speed diesel generator. :D
Listeroids
/ Chinese diesel generator? #22
I tried to get my Petrol genny to run on LPG but it would just stop after about an hour , i never found out why .
A couple of thoughts. On a small bottle of lpg it can "freeze" up not allowing the gas to escape. LPG is nice for a standby generator due to the storage of LPG, Gas and diesel need stabilizers and additives to keep for extended periods and different weather conditions. Also, with LPG a carbureted engine doesn't have to be run dry to keep the carb from shellacing.
/ Chinese diesel generator? #24
My Dear Watson , i think you have solved the mystery . An orifice has frozen over and stopped the flow . Good work .
I had this same problem trying to heat a house trailer in Northern Michigan with a 60# bottle of propane. I had to keep warming up the regulator to keep the gas flowing.
So help me out here. Take 5 gal of gas and lets say for simple figureing $4 a gal. $20. ( sometimes its a little less) and a jug of propane , like the one you use on a barbcue grill, that you can get at the 7-11 stores for say $20. (actual about $17. Which will run longer on the $20 of fuel and about how much longer? Or a small diesel gen the same size. (still $4 a gal)
/ Chinese diesel generator? #26
Hi! I have two 10 hp (Dek-diesel (China Yanmar clones)) They take about one liter hour at about 2500 rpm For Generator may be 1.5 liter hour. Engine must turn 3600 rpm for 60 cycles or 3000 for 50 cycles. Very fast for diesel . China diesel are good. But Lombardini or Yanmar are a lot better. I think Lp gas cost can be lower because less tax. Good luck ! Oldmech
/ Chinese diesel generator? #27
Our Diesel genny runs around 1 litre per hour . The standby Petrol genny runs between 2.5-3 litres per hour . So an eight hour day charging our house batteries cost's $14 in Diesel @ $1.75 per litre and it costs $37.20 in Petrol @ $1.55 per litre .
/ Chinese diesel generator? #28
ironhorse, how do you go getting parts for the kde? one of my mates was looking at one and asked me what i thought - i replied that i could identify a parts supplier therefore duck and weave imho.
/ Chinese diesel generator? #29
Parts are a bit of a problem here in OZ because the importers are low volume and don't carry a lot of spares . But in saying that most of the different brands are similar and in the case of the burnt out regulator i spoke of earlier , i sourced one from a different brand and it fitted straight in . Rings and bearings would not be hard to get for the engine and the genny could be rewound easily so getting out of trouble is not hard if you use your head .
/ Chinese diesel generator? #30
I bought a couple of the enclosed ones , 1x6kw and a 12kw . The 12 has a 3 cyl Daihatsu Diesel and is great except it runs @ 3000 rpm . With the power of the engine it should only run at 1500 rpm but the 2 pole generator is cheap for the Chinese to buy . The oil leaks on the single cylinder ones you guys are speaking of are easily fixed . It is the cheap 'O' ring that is fitted to the removable screen at the bottom of the crank case (black elongated plastic cap held in with 1 bolt) Fit a good quality one and the problem is gone . Also the ehaust manifold bolts come loose and the escaping hot gases burn the two wires going to the regulator which shorts the reg out . You need to remove the soundproof cover to tighten them . Ive had a good run from them , they are KDE brand , also the Honda clone pumps by Sinopower are exelent as well .
What should i expect to pay for one of these 6k gens or similar
Is there a differance in who makes the engine and how many different h.p ratings are there? I am talking about the ones in the 6k range also. On E-bay some are advertised as 10hp, one as 11 and one says theirs are 13hp. Naturally you want to get the best for your money. One has a two year warranty, one a one year, one no warranty at all. I dont place much faith in the warranty. But would be ok if they just supplied you with the parts, if it went bad (free) during the warranty. As crating the gen. back up and shipping it back would cost you $3 or 4 hundred. One mfg says they supply you with spare filters, parts manual, spare gasket set. I visited my neighbor yesterday, who bought one from Northern tool (not the exclosed one) and he said it was very fuel efficent, about 1/3 of his gas gens. He felt he could roll it around better and more portable than the enclosed ones. His major complaint was very noisey. I personally didnt think it made much more noise than my Coleman. I would not be moving mine around. As I have another gen. if I had to load it in my truck to used it some where else. I have heard that the enclosed ones are quite a bit quiter. The only problem is you have to remove all the sheet metal to work on it. I havent seen one of them. But it lookes like there is a lifting ring in the top center, and I could just put a chain through it and pick it up with my loader if needed. I still havent made up my mind as I have run onto a Onan, around 6K. and I think it is a 2 cyl and operates on only somewhere around 1500 rpm. which would make it pretty quite and smooth. It has only about 60 hrs on it. It is propane. Most people say I shouldnt have any trouble in getting propane. I've got to go back and look at it when I get a chance. I dont think propane would be quite as easy to get in a long range emergency as diesel.
/ Chinese diesel generator? #33
Well what do you know? Surplus Center is now selling the diesel engine that appears to be the one in my chinese gensets-
Surplus Center Item Detail
of course mine is configured a little different to use a larger fuel tank in the genset housing and has seperate controls, different muffler etc, but the crankcase/overall engine looks identical.
/ Chinese diesel generator? #35
I have a 4500 watt Diesel Generator with an engine that is exactly like a Yanmar. It came with a electric start kit. It has a fuel primer and a compression release. It bears the name GIO. It appears to be Chinese. Its an absolute B to start by hand so I have installed the starter, but still trying to figure out the alternater part to charge its battery. So far so good, but really noisy. When I bought it used and finally started it by hand , it blew smoke for 5 minutes then settled down. Extremely loud, but it runs my 220v 140 amp welder fine.
/ Chinese diesel generator? #36
My father gave me a diesel generator. I think he didn't understand that it was made in China (he never would have bought it). That thing is so difficult to start that I bought a small Harbor Freight generator to get it going! The HF genny does the emergency work and the Diesel is simple a boat anchor. I should get it out a run it though...
/ Chinese diesel generator? #37
Onan makes both 1800 and 3600 rpm units. I had a small 5kw 4 pole unit (1800 rpm) that ran on propane. Cast iron monster. Very reliable, but when onan sold out to cummins, parts were getting harder to find. Sold it to someone that had one just like it.
i would never get any chinese gen…period. Ive seen these thing totally fry houses depending on them for emergency power. If you get one thatworks, consider yourself lucky. But if you do you can probibly leave it turned off and read by the light coming off of the radioactive waste metal its made from….ok, so now im probably exaggerating.
