Checking Trans/Hydraulic fluid
/ Checking Trans/Hydraulic fluid #1
rmiller
When checking transmission/hydraulic fluid level should all cylinders (loader, etc.) be fully extended or fully relaxed - IE loader on the ground?
/ Checking Trans/Hydraulic fluid #2
Should be a drop in the bucket, as only the volume displaced by the rods can affect the total amount of fluid in the reservoir, which is gallons.
/ Checking Trans/Hydraulic fluid #3
Yes, on level ground, and like the first post unless you have the loader raised there should be no appreciable difference in the levels.
Thanks for the replys. I checked both ways and it does make a diff. on the dip stick of about 1/8 of an inch - not enough to worry about when talking gallons.
1963 Ford Falcon (A62613)
1963 Ford Falcon...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
2019 FORD F-250 SERVICE TRUCK (A63291)
2019 FORD F-250...
2004 John Deere 310SG 4x4 Extendahoe Loader Backhoe (A61572)
2004 John Deere...
John Deere MX10 (A64119)
John Deere MX10...
