Checking Trans/Hydraulic fluid
/ Checking Trans/Hydraulic fluid #1
rmiller
When checking transmission/hydraulic fluid level should all cylinders (loader, etc.) be fully extended or fully relaxed - IE loader on the ground?
/ Checking Trans/Hydraulic fluid #2
Should be a drop in the bucket, as only the volume displaced by the rods can affect the total amount of fluid in the reservoir, which is gallons.
/ Checking Trans/Hydraulic fluid #3
Yes, on level ground, and like the first post unless you have the loader raised there should be no appreciable difference in the levels.
Thanks for the replys. I checked both ways and it does make a diff. on the dip stick of about 1/8 of an inch - not enough to worry about when talking gallons.
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
2014 Land Rover LR2 AWD SUV (A61574)
2014 Land Rover...
Caterpillar 416-442D Backhoe Service and Parts Manuals (A63117)
Caterpillar...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59911)
2016 FREIGHTLINER...
2012 International Prostar (A63118)
2012 International...
2011 Ford F-250 Pickup Truck (A61573)
2011 Ford F-250...
