Checking Trans/Hydraulic fluid
/ Checking Trans/Hydraulic fluid #1
rmiller
When checking transmission/hydraulic fluid level should all cylinders (loader, etc.) be fully extended or fully relaxed - IE loader on the ground?
/ Checking Trans/Hydraulic fluid #2
Should be a drop in the bucket, as only the volume displaced by the rods can affect the total amount of fluid in the reservoir, which is gallons.
/ Checking Trans/Hydraulic fluid #3
Yes, on level ground, and like the first post unless you have the loader raised there should be no appreciable difference in the levels.
Thanks for the replys. I checked both ways and it does make a diff. on the dip stick of about 1/8 of an inch - not enough to worry about when talking gallons.
2016 DODGE RAM 1500 4x4 CREW CAB PICKUP TRUCK (A59912)
2016 DODGE RAM...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
2022 EZ-GO ELITE...
2003 Tennant 7400 Compact Industrial Floor Scrubber (A61572)
2003 Tennant 7400...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
