check timming kioti lb 2202
/ check timming kioti lb 2202 #1
frank360
Lakeland, LA
Mahindra 2615
trying to find out if anyone knows how to check injection timming the only thing my book says it should be 25 degrees before top deed center,the only thing i see is f1,f2,f3 on fly wheel but i do'nt know how to go about checking it i know i have 5 shims under pump but know nothing about timming.
/ check timming kioti lb 2202 #2
Frank
Do you happen to have a workshop manual for this tractor? It will help out alot.
To check timing (from LB2204 Workshop Manual)
1 ) Start and run engine at idle
2 ) Attach a timing light to the injection pipe
3 ) Check to see if the timing check window of the clutch housing is aligned with the F1 mark on the flywheel
4 ) If the timing of the fuel injection is off, adjust with shims. Each shim changes crank angle by approximately 1.5 degrees.
No timming light,where can i find one?
/ check timming kioti lb 2202 #4
Do a search on the internet for "diesel timing light" you should come up with some hits. Or check your local auto parts store. Just a warning they are pretty pricey.... Just be sure to get one for the right size fuel line.
Found this one pretty fast doing a search:
Diesel Timing Light
/ check timming kioti lb 2202 #5
Frank
Just checking to see if you had any luck with your LB2202 and getting the timing check?
Regards,
its ok every thing is fine now its working like it should the govnor linkage was set up wrong that why i had raw fuel,going to sell and by L-2800 kubota when i sell my kioti whats a good asking price in good condition 685 hours. thanks for your concerns
/ check timming kioti lb 2202 #7
It would be hard for me to say without seeing the unit, and performing an inspection. Glad to hear you got it all fixed up!
Swict 84in Bucket Skid Steer Attachment (A64553)
Swict 84in Bucket...
2022 EZ-GO ELITE...
Texaco Gas Pump Yard Art (A64557)
Texaco Gas Pump...
2021 YANMAR VIO25-6A EXCAVATOR (A63276)
2021 YANMAR...
2015 Hyundai VC2530152 53ft. T/A Dry Van Trailer (A64556)
2015 Hyundai...
2017 MAC Half Round T/A End Dump Trailer (A64194)
2017 MAC Half...
