Check Hydraulic Fluid
/ Check Hydraulic Fluid #1
Jg1
Cub Cadet 7195
I have a Cub Cadet 7195 compact tractor. When I go to check the hydraulic fluid before I start it. The dip stick is completely dry. I put the dip stick back in to check it again and it is dripping wet full. I’ve done this 3 mornings in a row with the same results. It never use to be like this.
How should I handle this?
Thanks
/ Check Hydraulic Fluid #2
Here's what my 7305 (next generation after yours) operators manual says about checking the hydraulic oil in a tractor with a hydrostatic transmission. Why you need to run it for a few minutes before checking, I don't know.
I looked in my owners manual. All it said is for the motor not to be running and the tractor to be on level ground.
I went out and checked it before I started it, same thing as before.
I started it, let it run for about a minute, shut it off then checked it. It was dripping wet on the full mark.
Shut it off and waited about 5 minutes, checked it again and it was still on full.
I guess as long as it shows fluid, I should be good.
It’s just puzzling that I’ve owned the tractor for many years and it was never like that.
Thanks for your reply to check the owners manual.
HD 24ft Free Standing Corral Panel with Feed Bunk (A65583)
HD 24ft Free...
GATOR UTV (A63276)
GATOR UTV (A63276)
1999 Nabors Chip Trailer (A62613)
1999 Nabors Chip...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
2014 Toyota Tundra Crew Cab Pickup Truck (A64194)
2014 Toyota Tundra...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
