3-Point Hitch Check Chains
/ Check Chains #1
Delphicoder
Virginia
Kubota B3200
I installed my Kubota three point hitch this past weekend. It came new when I bought the tractor, a bx25. While putting it together, all seemed well. but after putting a rear blade on it I when to tighten up the check chains. I noticed that the threads on one of them was all mangled, like it had been cross threaded. I could not get it to turn either way. The other one was fine. So I am trying to figure out what one of these should run price wise. The instructions that came with it list the part as K2561-3810-2. I did a search at Messicks, but it did not find it. A google search was not much help either. Probably not worth replacing, but not knowing much about tractors yet, I felt it would be best to be safe.
/ Check Chains #2
I'm sure you've tried to clean up the threads? You do want to either get those threads cleaned up and functional, or you'll have to bite the bullet and order/get warranty on the part.
The BX chain keeps is a constant source of irritation to me and others, as I understand. No matter, it must work and work as well as this system can. There is so much lateral pressure that without one's chains tightened, ie, snugged, something is going to end up broken, twisted or mangled. You cannot have implements just flopping or swinging freely around.
/ Check Chains
I stopped at the place where I bought the tractor, and they had one in stock. Twenty-five bucks later and i am all set :)
UNUSED JCT 2 PRONG BALE SPEAR (A65055)
UNUSED JCT 2 PRONG...
2011 Ford F-150 Pickup Truck (A64194)
2011 Ford F-150...
2017 Ford F-550 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2017 Ford F-550...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2004 Chevrolet Silverado 1500 Pickup Truck (A64556)
2004 Chevrolet...
36in Forks (A64553)
36in Forks (A64553)
